Question about Bass Pro Boating
Idles high - Bass Pro Boating
  • 2,926 Answers
High idle can be attributed to a few causes, one is a vacuum leak. What size engine? Horsepower? year?
Posted on May 11, 2010
1997. Idle seems a bit high. How can I adjust it? I'm getting awesomely high mileage both city and highway but i think it could improve still more and the idling speed feels too high.
The idle speed is controlled by the engine computer through the idle air control valve , there are no provisions for adjusting idle . If idle is to high or you just think it's high , you need to test ,don't guess . Watch this video that shows what happens when you adjust thing's that you should not . Ford IAC valve test how to adjust minimum idle speed How to do it correctly !
Jan 16, 2016 | Mercury Sable Cars & Trucks
High idle at start up 2200rpm then slowly drops but always seems high have to ride brakes to stop
Long High idle after start up - YotaTech Forums
www.yotatech.com/f116/long-high-idle-after-start-up-246386/
Dec 20, 2011 - aviator's Avatar ... When the high idle is no longer needed the piston retracts and the throttle ... Sometimes the piston gets gunky and slow to react... clean the ... you are already idling higher then normal the idle up will only be worse... for ... it takes to kick down when I first start it up, high idle is at 2200 RPM it ...Missing: lincoln
High idle at start up - F150online Forums
www.f150online.com/forums/v8.../306364-high-idle-start-up.html
Oct 27, 2007 - ... King Ranch · Lightning · Lincoln Blackwood & Mark LT · SuperCrew · SVT ... my 2000 when its been sitting goes up close to 2k then drops down in seconds. ... so what your saying is when it's cold outside I can expect it to start andidle at 2200 rpm. sounds pretty off to me. ... Vehicle: 2004 Ford F150 5.4L. 4.6l Intermittent High Idle. Why?
Jul 12, 2005
Dual remote oil filters????
Jun 29, 2001
More results from www.f150online.com
Nov 30, 2015 | 2004 Lincoln Aviator
2001 dodge dakota sport with 2.5 engine idles high when I start it up, continues idling high, when pushing clutch in to change gears it idles extremely high
Does it do it if you disconnect the idle air control valve ?
You need to know if its a vac leak or if the computer is making the valve open too far.
Feb 09, 2014 | 2001 Dodge Dakota
Does high idle consumes more gas??
obviously does, more RPM needs more gas
Mar 14, 2013 | Cars & Trucks
Car engine idles really high then really low, why?
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues. Engine idles rough.
There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------
Click the link below:-----
Ford Expedition IAC valve replacing
http://technoanswers.blogspot.com/2012/12/ford-expedition-iac-valve-replacing.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less?
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
GMC Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
1996 Camry intermittent engine failure while idle?
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
High rpm in neutral? Inconsistant high RPM in neutral?
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Vehicle stumbling at idle and shows code 54?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
Rough idle, staling and Erratic shifting?
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These details will help.
Thanks.
Feb 15, 2013 | 2003 Pontiac Grand Am
High idle then low idle
just do induction / throttle body cleaning - will solve high idle on start up
Nov 12, 2012 | 2002 Chevrolet Impala
What is high idle?
When a car is idling it is at rest.The idle setting refers to the engine revolutions or 'revs'.If the setting is increased so that the 'revs' are greater,the engine will not stall at rest.This is 'high idle'!
May 16, 2012 | Cars & Trucks
1989 f150 302 V8 fuel injected emissions problem. Installed new engine from Ford, blew SKY HIGH on low and high idle emissions. Emission numbers were 10-20x max legal limit (over 3000). Replaced the...
the O2 sensor works on one volt .5 is around the running voltage, i would refit the air hose as it will run the converter hotter at idle.
Apr 26, 2017 | 1989 Ford F 150
Idles to high
You may need an Idle Air Control Valve (a common problem), I would also change the thermostat as well. If its reading cold it will cause the car to idle high.
Apr 13, 2009 | Toyota Camry Cars & Trucks
Boating Logo
55 people viewed this question
Top Bass Pro Boating Experts
ray gallant
choprboz5
vinayghl
Are you a Bass Pro Boating Expert? Answer questions, earn points and help others
