Question about Pioneer VSX-D509S Receiver
Volume changes automatically
Every 6 months or so, my Pioneer VSX-D509S receiver will automatically change the volume level up and down. It seems to do this for several days, then goes back to normal. It has been doing this for the past 3-4 years. It is something occuring internally, as the remote control is not the cause.Otherwise, everything else has been fine with it for the 10 years I have owned it.
    Brigadier General:
  • 8,546 Answers
Just a wild guess.
Does this receiver have line-of-sight with windows? Some other Infra-Red source in or out of your home may be affecting it. Try covering the IR 'eye' on the receiver to see if it stops happening.
I have an IR on my Media Center PC and the l.e.d. on it will light up whenever it receives a command, no matter what remote I use. Of course, it doesn't actually do anything unless I use its remote. Occasionally, it will blink even when I'm not using any remotes, so clearly it is seeing IR from somewhere.
Posted on May 07, 2010
I can't get anything out of the speakers when I switch to 5.1
We can't make assumptions. Did you set it up in accordance with the manual(s)?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-D509S-Receivers-manual/id/385ci970/t/2/
Mar 15, 2011 | Pioneer VSX-D509S Receiver
How do i conect my tv to this receiver
That would depend on the capabilities of the TV.
The VSX-D509 manual is avalailable for free at retrevo.com.
http://www.retrevo.com/s/Pioneer-VSX-D509S-Receivers-review-manual/id/385ci970/t/1-2/
The receiver only needs a simple composite monitor output using a standard RCA cable so you can use the TV to operate it through its menus.
My TV has many video inputs of the various technologies, so I connect each Hi-Def video source's video directly to the TV and run the audio from them to the appropriate inputs on the Receiver.
If you feel the need to have the TV's minimalist audio run into the receiver just run an RCA pair from its audio output to any available analog input, but the sound will be limited to analog stereo. In the TV's setup find a setting for the audio output and select whatever closely resembles a 'fixed' level so you can mute or turn its volume down without affecting the audio out to the receiver.
Jul 16, 2010 | Pioneer VSX-D509S Receiver
Pioneer vsx 5900s cuts out when turn volume up
most amps do that if too high in volume.but check yr speaker ratings and connections
Jul 04, 2010 | Pioneer VSX-D509S Receiver
I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Oct 16, 2009 | Pioneer VSX-D509S Receiver
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
Overloads all the time under 40db.
Hi Glen. The thing with these new units is that they are so fussy when it comes to frequency range on the speakers. The frequency has to be within the range that the amplifier specifies, or you'll have problems. I suggest that you check your manual to see what the required frequency shuold be and take it from there. I have one myself and love Pioneer
Aug 02, 2009 | Pioneer VSX-D509S Receiver
I need Pioneer AXd7248 remote control manual that I can download.
I have your solution! We were having trouble with this too. As you may have known, the Pioneer AXD7248 came with a receiver, the Pioneer VSX-D409 / VSX-D509S. If you look up the manual for the receiver, you will find how to program the remote on page 23 of the manual and the codes starting on page 53.For the convenience of everyone else who googled AXD7248, here's a direct link to the page to download the manual: http://www.retrevo.com/support/Pioneer-VSX-D509S-Receivers-manual/id/385ci970/t/2/
Jun 25, 2009 | Televison & Video
Pioneer VSX-D509S Receiver Logo
191 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
