Question about Sharp Notevision PG-B10S Multimedia Projector
Projector displays keys locked message on screen and all buttons the projector are frozen
  • 144 Answers
Replace the main board and also try replacing the ir system.(maybe burnt out).
Posted on May 08, 2010
Hi. My Dell Latitude E6410 does not recognize a Epson Projector, model EMP-7800. How can I solve the problem?
Hi
you must tell the laptop to display out on the projector,
how to do that?! you must toggle the display path
Generally, there is button ( with Fn keys ) have dusplay screen sample on it, use it with Fn to toggle the display
Display have 3 modes:
  1. laptop screen
  2. outside LCD projector or monitor,
  3. or bith 1 + 2
you can press the keys 3 times ( at maximum ) to have the display on both laptop screen and projector
Good Luck
May 13, 2011 | Dell Latitude E6410 Laptop
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
What should the projector settings be if connected to a hp laptop.. and how?
The projector is capable of 1280x1024 and 1280x720. That is great for HD and gaming! Look on the function keys...An example would be F4 or F8...There will be a symbol of a TV screen. Press and hold the "alt" button and then press the key with the symbol on it. That tells the laptop to send the video display to an external display. You should see it on both your laptop and projector. Press the buttons again, ONLY the projector will have the image. A final press of the buttons will return you to laptop-only viewing.---rick
Sep 06, 2009 | Mitsubishi HC1600 Projector
Sony Projector VPL-VW 10HT 2 problems 1)The
there is a lock on the projector that needs to be removed. check the manual for the code.
Aug 19, 2009 | Sony VPL VW10HT Multimedia Projector
Projector appears to be in lock-out (exceeding 2000hrs on bulb)
1) Press the RESET button on projector for 3 seconds or remote control TIMER button for 3 seconds and display the total lamp used time. 2) Press the RESET button on projector or remote control MENU ON button during displaying the lamp used time. 3) Select the ?0? on the screen using the MENU ( ) button or DISK PAD.
Aug 12, 2009 | Hitachi CP840/940LAMP Projector Lamp for...
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
Shutting off Filter Cleaning Message
you need to turn OFF the message function under the expert tab on the "on screen menu"
In the state of Power ON, press each key in the order of: HELP, UP, LEFT, HELP
Press the Menu Key to display the menu and confirm that Expert is displayed below the menu.
Once you go into Expert mode, go to the Expert2 tab in the onsreen menu and set the message to OFF.
Hope that helps.
Aug 19, 2008 | Office Equipment & Supplies
Help me Please
I have just reset my lamp! Disconnect all cables but the power, switch on it will search for a source, the lamp timer message will display press exit untill it will give you a message to press menu to reset the lamp timer, it will give you a option to press left or right to reset. I used the buttons on the projector not the remote.
Jan 31, 2008 | LG RD-JT40 Multimedia Projector
Sharp Notevision PG-B10S Multimedia Projector Logo
302 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
