Question about IBM eserver xSeries 360 8686
NMI ISSUED PRESS ESC TO TURN OFF NMI IN IBM SERVER
    Problem Solver:
  • 5 Answers
Dear mugkifa ,
the above error indicates , a non maskable interrupt occurred in your server , there may be a change of malfunction of a hardware ,like add on cards
one more solution in ibm server is disablig the NMI interrupt by using jumper settings (inside motherboard)
see the below mentioned details , may differ with your server series please refer with series on http://www-947.ibm.com/support/entry/portal/docdisplay?brandind=5000008&lndocid=MIGR-5069937
System-board jumpers
The following illustration shows the switches and jumpers on the system board:
NMI ISSUED PRESS ESC TO TURN  OFF NMI IN IBM - migr-5069937_2.gif Note: Any jumper blocks on the system board that are not shown in the illustration are reserved. The following table describes the function of each jumper block:
Jumper Settings CMOS jumper (JP3) Pins 1 and 2: Keep CMOS data (default)
Pins 2 and 3: Clear the CMOS data, which clears the power-on password and administrator password Boot block jumper (JP4) Pins 1 and 2: Normal (default)
Pins 2 and 3: Recover boot block NMI (non-maskable interrupt) switch (SW1) Normal (default): No NMI issued
The NMI button that is on the rear of server, connected to this switch, has been pressed: NMI issued
Posted on Aug 11, 2010
Hp 6930p nmi channel check iochk
System I/O address specifications 970-071 NMI enable/RTC
What is Nmi Error On Hp Server error? The Nmi Error On Hp is the Hexadecimal format of the error caused. This is common error code format used by windows and other windows compatible software and driver vendors.
This code is used by the vendor to identify the error caused. This Nmi Error On Hp Server error code has a numeric error number and a technical description. In some cases the error may have more parameters in Nmi Error On Hp Server format .This additional hexadecimal code are the address of the memory locations where the instruction(s) was loaded at the time of the error.
What causes Nmi Error On Hp Server error? The Nmi Error On Hp may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Nmi Error On Hp Server error? There are two (2) ways to fix Nmi Error On Hp
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Nmi Error On Hp Server) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Dec 10, 2016 | HP Computers & Internet
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
Nmi error
Chip-set or memory error that relates to parity or ECC (error correcting) Try singling out your system memory and see if you still get this error.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Feb 05, 2014 | IBM Xseries x346, 1 x xeon 3.6 ghz/1 mb,...
Firsty my ibm x 236 server is showing 162: configuration error than Re-=booting due to unexpected NMI at F000:FF54
XSERISE 235 TYPE 8671J
1,NO VIDEO,NO BEEP
2,PCI-X SLOT5 POWER LED ON BUT IT HAVE NOT BEEN ABSENT
Jan 20, 2010 | IBM X236 Server
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
How to get into bios
Restart the computer and press F2 right away.
Jan 05, 2009 | E-Machines eMachines Desktop PC
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
How to go to boot settings in IBM 6578-PBU machine
Try each of the following: F1 F2 ESC DEL F10
Aug 26, 2007 | IBM NetVista A40 PC Desktop
IBM eserver xSeries 360 8686 Logo
2,509 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
