Question about Olympus FE-340 Digital Camera
The cameral lens, on my Olympus FE-340 goes in and out and then turns off when i'm trying to turn it on. ONLY 2 years old!!!
I hv the same problem the lens goes in and out...my frens gurl has one n its the same problem....its a nice camera but it worthless
Posted on Jun 15, 2010
2 Suggested Answers
  • 11967 Answers
SOURCE: The cameral lens, on my Olympus FE-340 goes in and
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
Power on olympus camera
Do you experience low battery? Have you tried using brand new and fully charged rechargeable batteries like NiMH or NiCd?
May 06, 2010 | Olympus FE-340 Digital Camera
My FE 340 Olympus Camera tries to turn on, but can't. Lens goes in and out several times then shuts off completely. Battery is fully charged.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 19, 2010 | Olympus FE-340 Digital Camera
How to fix my fe camera-340 when i turn on the
The problem is the firmware of the camera it seems to be corrupted.Firmware is the software installed in the camera which controls all the functions.Please contact any service center to upgrade the firmware as doing it yourself may harm the cam.
Thanks
Feb 16, 2010 | Olympus FE-340 Digital Camera
Olympus FE-340 dropped, won't power on any remedy?
You could try removing the battery for a 30 minutes, re-install, then try powering it back up. It sounds like something may have been damaged internally from the camera being dropped.
Sep 13, 2009 | Olympus FE-340 Digital Camera
Olympus FE-340 camera i turn on the power the lens goes in and out 2 or 3 times and the view is blurry in the view finder. The zoom feature has no effect when pushed to the wide setting and will turn off...
your lens may be damaged...your zoom assignments may need to be realligned if there are no broken parts. If there are broken parts in your lens it may be better to get a new lens
Aug 10, 2009 | Olympus FE-340 Digital Camera
Same exact thing......My mom thinks it needs a new battery.
Hi!
It sounds like your camera lens focus is stuck - could be sand or something in the focus gears - that's the weak spot of these lens. If you can't open the lens and check your lens focus gears yourself, you should contact your local Olympus service center or other camera service center. You can contact me too at toms.safranovs@gmail.com and I can give you a good price.
Hope this helps!
Tom
Jul 29, 2009 | Olympus FE-280 Digital Camera
Olympia fe-340 won't fully turn on
You have a bad lens, you should take into a camera repair shop. The only other thing that can be possible is the cable from the lens to the camera man board may have not be making proper contact.
Jul 02, 2009 | Olympus FE-340 Digital Camera
Fe-340 wont turn on
If the lens is stuck out, that either means impact or it got squished and messed up the lens mechanism. You can have that repaired.
Apr 20, 2009 | Olympus FE-340 Digital Camera
My olympus fe-340 wont turn on
the block flex strip seems damaged ...change it ...
Mar 05, 2009 | Olympus FE-340 Digital Camera
Olympus FE-340 Digital Camera Logo
371 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
