Question about Lexmark Z33 InkJet Printer
Lexmark Z33 Cable Problem
My uncle pulled out the power cable out of my Z33 while it was on
i reconnected the power cable, and now the gray button light blinks but the power light remains solid
Windows does not acknowledge that the printer is connected. what do i do??
  • Anonymous Jun 22, 2008
    I have exactly the same problem, the paper light is always blinking. Also, when the printer is powered, it is automatically "on" and I cannot turn it off (except by unplugging it).
  • jonatp Jun 23, 2008
    When the printer is powered, it is automatically "on" and I cannot turn
    it off (except by unplugging it). Also, if I open the lid, nothing
    happens (even if normally the ink cartridge would come in the middle,
    without any kind of software installation or computer connection)
  • 69 Answers
Disconnect printer from your computer. Delete Lexmark software from your computer and start afresh. Once you have loaded software and any drivers try to print a document.
Check in settings/printer that file that you want to print is being transferred from your PC to the printer. You will see the doc in the printer dialogue box. Hope things are sorted.
Posted on Oct 03, 2008
    Guru:
  • 377 Answers
Hi dear
trying to change port of usb where your connect, or try to change your USB cable
oke
Posted on Mar 27, 2008
Lexmark Optra S1250 Printer - Message "38 Memory Full". I tried to power on the printer without the printer cable attached.
You may have a document (or multiple copies of the same document ) stuck in the print queue. Turn off your printer, then pull the plug. Got to the control panel (or equivalent) on your computer and check the Lexmark print status for content and delete it, if possible. Reconnect the data cable to the printer, then reconnect power and turn it on to initialize. Cue up the print job again and go.
Feb 16, 2018 | Lexmark Office Equipment & Supplies
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
Error code 0504
Problem Error: " Hardware Error 0504 " on the LCD Display Solution When you try to run the Clean option from the Ink Cartridge menu, the following message may appear: Hardware Error 0504.
To resolve this issue:
  1. Take both cartridges out of the printer.
  2. Switch off the printer using the power button.
  3. Disconnect the power cable from the back of the Lexmark X5150.
  4. Leave the power cable disconnected for 30 seconds.
  5. Reconnect the power cable and switch the printer on again.
  6. Reinstall the cartridges. (Follow the instructions on the LCD screen or refer to the following document: http://support.lexmark.com/index?page=techlibraryKB&linkSelected=node2^subnode0&channel=techlibrarykbchannels&locale=EN&userlocale=EN_UK
Sep 02, 2011 | Lexmark X5150 All-In-One InkJet Printer
I need to know how to remove my info from my lexmark 4270 series before I trade it in.
1.Disconnect the power cable from the back of the printer.
2. Hold down the Stop/Clear button. (To the right of the Black Copy button.)
3.While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
Thanks for using Fixya.
Feb 27, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have a Lexmark Z33 printer and have just purchased an HP computer with Windows/Vista. I my printer compatible?
Windows Vista operating system is not supported on Lexmark Z33. Also, Lexmark does not provide the drivers compatible with Windows Vista for this printer model.
For more detailed specifications and support, visit the Lexmark Z33 support pagee by clicking this link.
On the page which opens, click on the "TECH SPECS" tab to view further details.
Hope this answers your query. Thanks for using FixYa
Nov 21, 2009 | Lexmark JetPrinter Color Z33 InkJet
Hardware error : 0502
  1. Switch off the printer using the power button.
  2. Disconnect the power cable from the back of the Lexmark X5150.
  3. Leave the power cable disconnected for 30 seconds.
  4. Reconnect the power cable and switch the printer on again.
  5. When the printer powers up, you will need to select the desired settings.
Jan 29, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error o504
It shows color cartridge is missing because either the cartridge is not well placed or it is not there.
  6. Reinstall the cartridges. (Follow the instructions on the LCD screen or refer to the following document: How to Install the Cartridges in the Lexmark X5150)
Jan 11, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark Z33 InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
