Question about Trendware TRENDnet TEG-S2600i 26 Port 10/100 SNMP Stackable Switch with 2 Gigabit Ports or 2 mini-GBIC Ports (NETHTEGS2600I)
Resetting the switch
I forget the ip,usrname,login of my trendnet TEG-S2600i switch Now i want to configure it for some other purposeHow can i reset it to the original factory default settings?
  • 476 Answers
Heres the online manual for this unit,
http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=4938
Its full of info that covers just about everything youll ever need for thiis unit
Hope this helps,MISTERDJ
Posted on May 07, 2010
Trendnet IP camera
you can do reset for the camera and try to re configure. or change the cable.
Sep 20, 2013 | Trendnet Home Security
How do i cable 10 computers, a docsis 3.0 modem, 8 port edgewater 881 router and 5 port trendnet TEG-S5G unmanaged switch
Connect 7 computers to the 881 router. The last port on the 881 router go to Trendnet switch. Connect the last 3 computers to the Trendnet.
Feb 11, 2013 | Computers & Internet
Hi i have trendnet te100 s24 switch and i want to do some configurations on vlans but i do not known how to do that especial getting into the switch interface can you help on this.my regards to you
Usually all those switches are plug and play ..and do not need much configuration ..but if you want to make changes or you changed the way you connect to the main internet source ...you have to use the same computer that was used first for configuration ..(it will be seen as admin ) ..and the log to the settings will be made the same as for a router..Look on the back of the switch ..and see what IP address has from the factory ..and type the IP address into the browser and hit enter..
for example in internet explorer ..write on the address bar ..:
http://192.168.1.1
(this si just an example ..but the ip for the switch will be written on its sticker
it will take you to the log in page ..and in there if nothing was changed .. ..you have to complete the lines with the words admin ..and password..or with the ones you selected when you first configured it ..
In case you forgot all these..it should have a hidden button that will allow you to reset it ..and after that it will be to the factory defaults and will accept the IP on the sticker and the words specified in the manual for login ..to settings ..or ..will go to settings without the log on screen .
Nov 16, 2011 | Trendware TRENDnet TE100-S24 10/100...
I forget my ip of TEG-S2600i 24-Port Ethernet
At the back on your switch there is a reset button. Press and hold it down for 10 seconds to reset it.
Default ip address of this switch is 192.168.0.1
May 07, 2010 | Trendware TEG-S2600i 24-Port Ethernet...
Trying to configure the computer TCP/IP setting but not getting the result.Computer not successfully connected to the router
1. Use a know good straight through cable
2. reset the router
3. release/ renew the IP
4. Make sure you have DHCP set to automatic
Apr 26, 2010 | Trendware TRENDnet TEW-435BRM 802.11g...
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
Password was changed
If you forget the password, press the “Reset” button in the front panel
of the Switch, the current setting includes VLAN, Port Setting… etc.
will be lost and the Switch will restore to the default setting.
Jan 15, 2009 | Trendware TEG-S2600i 24-Port Ethernet...
Networking
The computer you are conserned about most likely doesn't receive DHCP, but either manually configured or gets the APIPA. The best way to check if that is the case to run ipconfig /all in command prompt.If adress starts at 169. search for break in line. If it is some manual configuration change it in TCP/IP in network connections properties. Have fun.
Jul 01, 2008 | Trendnet TEG-224WS 24-Port Ethernet Switch...
Impossible Firmware upgrade
That path should be location of the file you downloaded from trendnet site. The password is set up password for router. Hope you remember that one.
Nov 08, 2007 | Trendnet TEG-224WS 24-Port Ethernet Switch...
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
See all Trendware TRENDnet TEG-S2600i 26 Port 10/100 SNMP Questions
Trendware TRENDnet TEG-S2600i 26 Port 10/100 SNMP Stackable Switch with 2 Gigabit Ports or 2 mini-GBIC Ports (NETHTEGS2600I) Logo
181 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
