Question about Pentax Optio E80 10MP Digital Camera with 3x Wide Angle Optical Zoom and 2.7-inch LCD
Lens assembly does not extend when the camera is turned on. Seems jammed into the camera body.
  • Pentax Master
  • 19,396 Answers
Hi.
This is a common problem , generally indicated as lens error. The problem is often caused by dirt or dust in the lens gears.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
You can attempt tapping gently the back of the camera while turning the camera on. Sometimes this can help the lens out.
If that does not work, then the lens must be taken apart.
I summarized the problem in this article: Lens Error.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Regards.
Posted on May 07, 2010
Easyshare cd82
Hello Bob, Sounds like drive assembly failure, the plastic gears strip and the pieces jam the drive motor assembly. No battery will help this problem. This is a high dollar repair.
Best Regards, Russell
Dec 29, 2012 | Kodak Easyshare CD82 Digital Camera
Sony cyber shot camers lense will not open. it seems to be stuck or jammed
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started having trouble.
Here is how to fix it.
Before trying any of the suggestions, make sure your Camera has fresh batteries in it.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
I hope this helped you. Thank You for using FixYa
Jan 12, 2011 | Cameras
My camera turns on then beeps 3 times then shuts off is it broken or is there a reset button?
The three beeps mean that the lens motor is unable to extend the lens assembly.
This could be due to a low battery situation, but the most likely cause is the lens drive train stuck or jammed. You'll find generic instructions on solving some cases of jamming here.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Unfortunately, more serious cases (due to falls, shocks, and most of all, the camera being turned on while some resistance prevents the lens from extending: e.g., if the camera accidentally turns on while in a pocket) require the repair shop.
Apr 27, 2010 | Samsung Digimax S730 Digital Camera
Lens error
This seems to happen when something (water, sand, dust) gets trapped in the lens mechanism. Has the camera been somewhere filthy before?
The recommended methods include taping on the bottom of the camera, rapping it on a table, and pressing hard on the lens. If the lens moves when you turn the camera on, try keeping your hand on it so that it's forced back into the camera body. A can of compressed air squirted around the lens is also a possible fix... but be super careful with that stuff, a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff to your camera, but if you're careful you may be able to get it working again without having to get it serviced.
Jul 04, 2009 | Kodak EasyShare C613 Digital Camera
Canon 20d - lens stuck / jammed
HI BRIAN ,,I AM SAGHA CAMERA REPAIRER,I THINK UR PROBLEM OCCURS DUE TO JAMMING OF PLASTIC MOUNT ON THE METAL BODY OF 20D.TRY THIS
1} LUBRICATE THE JUNCTION WHERE LENS GET ATTACHED TO THE BODY WITH KEROSENE THEN TRY TO RELEASE THE LENS.REMOVE THE BATTERY FROM CAMERA ,TRY AND HEAT UP THE JUNCTION WITH HAIR DRYER A LITTLEBIT THEN TRY TO RELEASE THE LENS.
2}IF THIS THING ALSO DOESN'T WORK THEN YOU HAVE TO SACRIFICE THE LENS PLASTIC MOUNT PUT SOME SHARP KNIFE LIKE OBJECT IN THE JUNCTION OF LENS & CAMERA & THEN PUSH IT UPWARDS WHICH WILL BREAK ONE OF THE PLASTIC LENS MOUNT COLLOR AND LENS WILL COME OUT WITHOUT DAMAGING YOUR CAMERA .LATER YOU CAN GET REPLACED THE LENS MOUNT FROM SERVICE PERSON. BUT NOW ATLEAST YOU CAN USE CAMERA WITH OTHER LENSES.
Sep 29, 2008 | Canon EOS-20D Digital Camera
Nikon Coolpix 4100
How wbout changing your batteries. mine does this if my batteries are dead.
Hope this helps
Jun 08, 2008 | Nikon Coolpix 4100 Digital Camera
ERROR REMOVE CAP LENS
I had the same problem with mine after I dropped my camera when it was opening up after turning on. It feel directly on the lens and ever sense has told be to remove the lens cap.
I’ve disassembled the camera and discovered that the zoom motor drive assembly has a small set of plastic gears inside that are quite fragile and like mine are easily broken. You’ll find the zoom motor after taking the back assembly of the camera off. It’s located on the bottom left side of the lens assembly if you're looking at the camera as if you were taking a shot.
Here’s the part no. from the Panasonic support web site.....
L6DAAAHB0001
ZOOM MOTOR
46.07
May 28, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
Broken zoom lens...
Hello This is a pretty usual type of problem. The lens assembly is composed of some lens and some servomotors that will move them around or focus them properly in order to get a sharp picture. This is a delicate part of any camera. Sometimes one of the small parts in the lens assembly get out from their positions and damages or jams other components there. Therefore when you start the camera it produces weird noises as it tries to extend the lens. A camera doesn't know where the lens are at the moment you start it. It will power up the motors for a small amount of time, as it knows that if the motor works for about 1-2 sec the lens should move and extend. If this doesn't happen the camera gets confused and gives you errors or makes strage noises as it powers on the motor but it can't move the lens because they got jamed or are fully extended. Only a service center can fix this because lens mechanisms are very fragile and require specialised hardware to be realigned or repaired. In your case it would be adviceable to ask them an estimate of the repair, for you to know if it's worth it. It can be a simple job like putting back the piece that got out of place, but also it can be a situation in wich the whole lens assembly must be changed because of extensive damage recieved when the motor forced the lens to extend. It is also a good thing to do, NOT to power on the camera anymore as it can damage itself furthermore. Sorry as I can't give you more detailed tips, this isn't the do-it-yourself type of repair, even the service centers are having problems with this repairs. Good luck however, maybe it's a simple thing.
Mar 15, 2007 | Concord Camera Eye-Q 4360z Digital Camera
Lens on Casio EX-S100 Won't Zoom
(EX-S100) You need a new lens assembly. I know this from experiece because I have the same camera and it tried to extend while in its case as well. I found that there are plastic gears that extend this lens assembly and that they are basically destroyed when the lens assembly is not allowed to extend on power-up. I have searched for a replacement part with little success. I found one repair shop that would ship me the part for more than the original cost of the camera. Good Luck!
Sep 03, 2006 | Casio Exilim Card EX-S100 Digital Camera
Pentax Optio E80 10MP Digital Camera with 3x Wide Angle Optical Zoom and 2.7-inch LCD  Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
