Question about Lenovo 3000 J Series 2.10G Xpp PC Desktop
Combo drive not working as well as ON/Off button on CPU not funct
I purchased the said system 2 year back and since begining there was a problem of noice which was rectified by service engr. but problem with on off switch remained unattended which is now totally out of order. Meanwhile the combo drive is not reading or writing any CD
    Champion:
  • 217 Answers
Hi i may not be able to help you with the power problem but i do have here a solution on your combo drive and hope it would work
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
Posted on Jun 02, 2010
I have a new canon Image Runner 2530 it has an error code E-000000,
add.funct 2+8 add.funct. copier function clear err ok shut off then on again.
Apr 14, 2012 | Office Equipment & Supplies
Everytime I start my computer, I get: Drive 1 not found: Serial ATA, SATA-1
Try this. Sometimes the CD info gets messed up in the system registry. This little utiltity usually fixes it. Unless the CD has gone bad, that is.
Feb 28, 2012 | Dell Dimension 9200 PC Desktop
I cant burn any dvd, but cd r or rw are capable . mayber the driver is out of date..please help me.
hi
perhaps the CD media you purchased is not compatible with your CDROM drive ..?
what is the model number oif the CDROM ? what computer model is used in ?
Nov 15, 2010 | Computers & Internet
I have a 5.8 Ghz phone system. Someone had turned the ringer off both line of one of my phones. How do I restore both ringers?
On the handset,there should be a function or funct button.Hold it down or press it.You cycle through the options by either funct button or directional button(I think funct).Once you get to set rings,I think that is when you use the directional button to set the rings.Keep cycling through options until it is all done.You may have to do it for both handsets.
Jul 05, 2010 | Lands Phones
I have a 651 Combo-L (MS-6769-010) motherboard and I would like to add in a Barracuda HDD of 160 GB and a Pentium 4 3.2Ghz processor. Any ideas if the board can take these?
The hard drive should be OK, however you did not say if it was IDE or SATA. IDE will work, SATA is not supported.
The CPU you listed is not supported. You may have a look at MSI support:
MSI 651M-Combo CPU Support
Jan 25, 2010 | MSI 651 Combo-L (MS-6769-010) Motherboard
ASROCK K8 Combo Z When I turn on there is no POST no beeps. Fans om Mobo and on graphics card spin but nothing else happens. I can not even turn off using the computer on switch I have to turn on at the...
Hi c_j_quinn,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck
Mark
Nov 06, 2009 | Asrock K8 Combo-Z Motherboard
Have a canon ir-5570 w/ error E00000-0010 will not allow me to reset code Any ideas? Tried the reset procedure of ad.funct 2 & * adfunc will not go into mode
press ad.funct. then press 2 & 8 keys at the same time,
then press ad. funct. , copier display shows setup mode go to (function)
tab and press clear error.
Aug 20, 2009 | Canon imageRUNNER 5570 Copier
Madden NFL 07 instruction booklet
There are two optaions for you to find one, one of the simpler ones would be to find a video game store and ask if they have the booklet in stock and they should be able to give you one, or you can try e-bay, im sure there is something on there. I hope I have helped you in anyway.
Wayne
Jun 26, 2009 | EA - Electronic Arts Madden NFL 07 for...
Lights, no action
CHECK RAM by putting some other working RAM , remove the cpu fan then install again,
Oct 21, 2008 | ASUS A8V-MX Motherboard
Laptop system board
you have a dead short in electrical most probably everything is stuffed
Jul 25, 2008 | Intel Motherboard
Lenovo 3000 J Series 2.10G Xpp PC Desktop Logo
44 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
