Question about Intel D850MV Motherboard
Bios setup not open & keyboard nt work - Intel D850MV Motherboard
    Master:
    Sergeant:
  • 460 Answers
First you check your keyboard is OK. If it is OK then your motherboard has been faulty.
Posted on May 10, 2010
My keyboard will not work
when booting up the computer push F11 to access bios
high light standard cmos setup
see if the
keyboard is turn on and if the computer see keyboard make model should display on screen F10
save & exit setup
Feb 25, 2015 | Computers & Internet
Foxconn nt-a3700 does not power up
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps
Jun 20, 2012 | Foxconn nt-A3700-0H0WBANA Black Mini /...
Hi, I need keyboard and mouse start in before windows.my is not
The USB keyboard & Mouse operation before windows is loaded is controlled by the BIOS. Go into your bios setup and make sure USB keyboard support is enabled.
Mar 01, 2011 | Dynex Keyboard/Optical Mouse DX-CKB102
Can't get into the bios for a presario 4716
This is what the Compaq site had to say about the BIOS utility for your system (Source: Compaq): • • • •You may have difficulty accessing the BIOS Setup utility screen, because you must press a specific key(usually F1) very quickly before the Windows screen appears. If you do not enter the BIOS Setup screen on your first try, repeat the following steps until you are successful.
To open the BIOS Setup screen:
1. Turn off the PC and wait about 5 seconds.
2. Turn on the PC.
3. When the first screen appears, press the F1 key on the keyboard. (You can press the key more than once.) The BIOS Setup Utility Main menu appears.
NOTE: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
4. Use the keyboard to navigate through the menus.
You may need to remove the battery and then back in.
Jul 21, 2009 | Computers & Internet
Mouse and keyboard freeze.
its a very common hardware fault with these laptops, can you open setup or bios? that is opened right when the power is turned on the and screen says press F2 to enter bios or setup, if you can't enter bios then you have a faulty motherboard, usb ports don't work either? (usb keyboard and mouse don't work?)
May 13, 2009 | Acer Aspire 3100-1405 Notebook
This mb will not accept keyboards
if the keyboard is working fine with other pc's except this motherboard i suggest you to enter the Bios setup by pressing the F2 or Del key before the system boots and set the option Halt On in the Bios setup to----> All error ,but Keyboard
May 08, 2009 | Computers & Internet
Bios does not find PS2 keyboard/mouse
Did you go into the BIOS and set it to recognize the USB Keyboard after you reset the BIOS? Is windows not noticing it or the BIOS. You stated that it recognized the USB keyboard and then said that it did not.
What does all of this mean? USB keyboard does not activate "del" setup.
If it does not work, it is because you reset the BIOS and did not change the settings back for the USB keyboard.
I hope that I fixed your problem.
Jun 04, 2008 | AOpen AX4BS (91.32Q10.002) Motherboard
Laptop function keys are nt working
2 possible solutions...
Reset the BIOS: Works in most cases
Reseat the keyboard: Sometimes it is possible, that the keyboard connector comes loose and thereby causing a malfunction with some keys or overall fails to work.
Apr 17, 2008 | Computers & Internet
Intel D850MV Motherboard Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
