Question about Sport & Outdoor - Others
How to wire up to dual battery - Sport & Outdoor - Others
  • Sport & Outd... Master
  • 12,061 Answers
That's how they go..you didn't say what, what the application was for, but anyway that's how you wire any batteries for series & parallel..
http://www.fridge-and-solar.net/dual_bat.htm
http://www.4wheeloffroad.com/techarticles/dual_batteries_backup_battery/index.html
http://www.ehow.com/way_5791353_dual-battery-wiring-guide.html
Go to those links above they will show you what to do, and how to do it.
Posted on May 07, 2010
Remote does not work and have changed all batteries
if the remote does not work and the receiver box and the transmitter have new, fresh batteries have you re-learned the receiver? A lot of remote assemblies have to re-learn the frequency when the batteries are changed. The loss of power causes the code to be wiped clean so the learn function has to be reactivated when ever new batteries are installed. If that is not the problem check the wiring. Obviously check for good connections but depending on the power source for the control valve most wires for remote will have a dual plug so it is possible to short the remote to run a wall switch or a toggle button. For instance in a millivolt control valve the heat from the thermocouple creates the power to open and close the valve. Even if the remote is functioning of the thermocouple is not properly connected or the solenoid that opens and closes is damaged the remote will not activate the valve. If there are dual plugs to allow the connection to have two controls one or the other of the dual plugs will take precedence because of the simplicity of the electrical current. If something metallic is close or touching the dual spade it can short the connection.
Mar 13, 2014 | Napoleon "Prestige I P450RBNSS" Gas Grill
Dual battery wiring
You will get several ideas as to how they should be wired but the place to get the right advice is from an accessories shop that sells off road equipment and does this set up all the time
Dec 01, 2013 | Cars & Trucks
I have a dual marine battery charger on my boat that is wired thru a 1-2 or both switch both batteries are 12 v batteries and i was wanting to know if i could add another two 12v batteries to the sy
It sounds to me like you have an Ad-A-Battery system or something similar. Your dual battery charger has two sets of output leads. Those leads should be connected DIRECTLY as one set of leads to battery #1 and one set of leads to battery #2. Your 1-2-both switch should be OFF when you are charging. You will, I suspect, be supplying current to your motor and other boat circuits by having the switch on and running your charger through that switch. Adding two more batteries could be accomplished by buying a four battery charger (four sets of output leads) or buying a second dual battery charger. When you only want one AC plug-in you connect both charger AC inputs to a small junction box that is fed current by the AC plug-in. That will be nice and simple and safe. Of course, you need to check wire size to make sure you have proper size for the length of your wire runs.
Mar 10, 2013 | Marinco Guest 2620 Waterproof Charger
3 marine batteries on a dual charger
You don't. It is called a "dual" battery charger for a reason, it charges two batteries. Guest makes very nice three battery chargers. Buy one of those and install it as per the instructions. You'll be much happier as well as safer.
Jun 11, 2012 | Marinco Guest 2620 Waterproof Charger
2000 Honda Civic ex have installed dual xdvd9131 after leaving for 1 day the battery is dead
wire the red wire onto ignition switch so the power is disabled when the ignition is off
Apr 05, 2011 | Dual Car Audio & Video
I have the "Dual XDMA7650" receiver installed in
sounds like you have the two wires red and yellow mixed up. you want the memory to be constantly on so then the memory cannot be lost, and the red accessory to be switched on when the ignition is in the on position.The ignition, if on will allow your stereo to begin running.
Dec 02, 2010 | Dual Car Audio & Video
I have a honda accord 91 i put a dual aftermarket head unit and it powers up but no display all wires are connected properly. please help!
its the igniton wire hook it on to the battery and see if the deck works if thats the problem plug the igniton wire into the fuse box 10amp if you got on
Jan 11, 2010 | Dual Car Audio & Video
Wiring ??? I'm installing dual 12 volt battery's
pos to pos and neg to neg for 12 volt but if your system is 24 volt thats a different story it will be pos to neg.and pos to neg
Nov 02, 2009 | Ford F-450 Cars & Trucks
Dual SBX554
POWR TO BATTERY FOR WHAT?DOES THE SPEAKERS HAVE AN AMPLIFIER? NEW RADIO? SPEAKERS ALONE ARE NOT CONNECTED TO BATTERY ,UNLESS THEY ARE POWERED SPEAKERS,USALLY SUB-WOOFERS HAVE THEIR OWN AMP.iF YOU ARE CONNECTING A AMPLIFIER START WITH A FUSE SAME SIZE AS THE AMP,CONECT 1ST TO THE BATTERYTHE TO THE FUSE RUN A SIFICIANT GAUGE POWER CABLE TO THE AMP.GET THE GOUND FROM A PART OF THE CHASSIS CLOSE TO THE AMP,ALSO SAME SIZE OR LAGER GAUGE WIRE.THEN YOU HAVE TO RUN A REMOTE SWICH WIRE FROM THE BACK OF THE RADIO TO THE AMP.iF RADIO DONT HAVE REMOTE ,CUT INTO THE POWER ANTENNA WIRE .RUIN YOU RCA CABLES TO THE AMP AND WIRE YOU R SPEAKERSMbUT FIRST DISCONNECT YOUR GROUND FROM THE BATERY MOST IMPORTANT.ANY '?'S.WRITE BACK RATING PLEAse.
Oct 26, 2007 | JC Whitney - Dual Blue Led Speakers Car...
Sport & Outdoor - Others Logo
13 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
