Question about Samsung ML-2240 Laser Printer
Toner not responding after refilling - Samsung ML-2240 Laser Printer
  • print_servic May 07, 2010
    short the formatter card chip
  • 4,041 Answers
Hi there
Did you reset the chip on the toner after refilling, try going into the Menu and reseting it.
Posted on May 07, 2010
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
Brother dcp 7055 printer toner ended error
i haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
Jan 10, 2012 | Office Equipment & Supplies
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
Refill toner cartridge
The toner cartridge is designed to dispose once finish... Not recommended to modified and refill...
Feb 17, 2010 | Toshiba E-Studio167 Copier
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned...
we can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Nov 05, 2009 | Brother MFC-7820N Printer
SHARP AR-203 copier unusable after refill
Change the unit chip or reset him.
Sep 01, 2009 | Sharp AL 1631 Copier
Catridge refiling
Smartest thing to do s to call Lexmark and purchase a new toner cartridge.
Lexmark does not allow for the use of refilled cartridges in any of their products. In fact, they will void printer warranties and not respond to any print quality question.
Laser printer cartridges have what is called a "Smart Chip." One of its purposes is to protect against the use of refilled toner cartridge.
Also, as an FYI, a toner cartridge that is refilled does not mean that any of the internal parts have been upgraded to "Equivalent to new" condition.
One final thought, it is illegal to hack around proprietary code. I believe it is an Intellectual Law issue.
Oct 21, 2008 | Lexmark Optra E312 Laser Printer
Refill
Hai
Well u can refill the toner,to refill the toner u should contact the nearby service station to refill.
Sep 09, 2008 | Xerox Black Toner Cartridge 25000 Page...
Refill toner in dell 1710
hi fireind
take out ur toner form your printer take the toner nearest printer ink refiller he will refill it he will chage for it $5 to 20$
Apr 08, 2008 | Dell 1710n Laser Printer
Samsung ML-2240 Laser Printer Logo
260 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
