Question about GPS
I just bought a Tsunami 1.2 Farad Capacitator from a fren but the fuse is burnt out. Where would i look for one and how much? Ive typed in everything possible to look online but cant find one.
  • 4,472 Answers
Do you know how many amps the fuse is? Do you have the exact model number of the cap? This link may be able to help you.
http://www.dealtime.com/-80+amp+fuse
Thanks,
Lee
Posted on May 07, 2010
What are the causes of tsunami
Usually caused by an under sea earthquake.
Check out this WEB site for details.
http://wiki.answers.com/Q/What_causes_a_tsunami
Feb 14, 2013 | Tsunami Lite Wave Capacitor 2.0-farad with...
Pump is flowing at 1/3 capacity. I replaced the fuse after it blew not it runs buy very slow....I replaced it with the required fuse
the fuse is only a circuit protecter, it will not cause your problem. have you tried replacing filter? check voltage at pump for correct volts. my system has 2 wires, 1 is low speed, 1 is high speed.
Jul 18, 2011 | Attwood Tsunami Cartridge Pumps Tsunami...
Need wiring diagram for tsunami 1.2 farad capacitor cap.
After a bit of searching I found the instruction manual:
http://a248.e.akamai.net/pix.crutchfield.com/manuals/120/120pp912u.pdf
Hope it helps.
Mar 05, 2011 | Metra Tsunami 1.2 Farad Capacitor
I have a 1200 watt amp and 2 12 in pioneer champions and it keeps killing my battery how do I hook up this capasitor I just bought?
first make sure your power wire is directly hooked to the battery, {make sure ure in line fuse is pulled} power wire that goes to positive of power cap , ground wire is grounded to chasis, now attach aditional power wire to amp and aditonal grond to amp . make sure all conections are solid and tight { also make sure inside of power cap is tight as well after long periods of time the insides loosen } i have 2 -1,000 watt sony xploid amps and 2- 1,200 watt sony expoid subs and they pound hard . i probley should have 2-1.2 farrid caps for what i have but it seems that its holding its own
Dec 04, 2010 | Metra Tsunami 1.2 Farad Capacitor
Hey i had 2 car amps +for 4 speakers(140W maxi) and a sub 12inch
1 cap, either .5, 1 or 1.5 farad will be fine. they make 5 10 and 20 farad that cost way more than u need to spend for 400 watts RMS. i like the rockford fosgates, you can get a low cost Tsunami, just make sure you follow the charging instructions.
Oct 20, 2009 | Car Audio & Video
1 amp cuts off
i had this same prob. & i run 2 amps as well, cameto find out i had a neg. & positive touching , so check all ur wiring for tht amp..
Apr 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
I was given a tsuname 2 farad
It doesn't matter...Just make sure your negative and positive terminal hookeups are correct. (as in, don't connect a positive wire to a negative terminal).
Mar 22, 2009 | Tsunami Lite Wave Capacitor 2.0-farad with...
System not playing
Sounds like the output transistors on the amp are blown. Were you slammin when it stopped or how did you find out it stopped working. It could be the sub failed then caused the ap to go which is why you get a little something from the JL.
Feb 11, 2008 | Car Audio & Video
GPS Logo
14 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
