Question about Maytag Performa PAV3200
Maytag washing machine
Washing machine goes off balance really easily machine just over 5 years old
  • cassidy6 Mar 28, 2008
    thanks ,but i havnt seen a concrete block in the bottom of a washing machine,the type you are talking about must be very heavy
  • Anonymous Apr 11, 2009
    maytag washing machine gets out of balance very easily model PAV 2300 AWW
    Scholar:
  • 74 Answers
Hiya .. would suggest you having a look at the balance around the drum, ( normally heavy concrete blocks)... locate the fixing bolts and tighten them up ....should sort your prob.
Also make sure that the washer is fairly even and tight on its legs.. this is what usually causes the problem in the first place..
Regards Faggly
Posted on Mar 27, 2008
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
DC Code on my maytag top loader washer comes on during the spin cycle and wont drain the water sears has been out over 5 times in 5 years to rebuild this machine everytime
Below is a link to a service buletin from Maytag stating the reasons for the DC Error, It's a balance issue and could require a software update to the electronics
Link:
Mar 07, 2012 | Maytag Neptune Washing Machines
My Maytag goes out of balance and bangs loudly
This is usually due to the floor not being perfectly level, and as a consequence the washing machine not standing firmly on all 4 supports.
There should be at least 2 adjustable feet under the machine, try to make it stand as level as possible, with uniform load on all four.
If you have a bubble level it may help you establish, if there's an obvious slope on your floor and adjust the machine so that it's well levelled.
Oct 30, 2009 | Maytag HAV2557 Top Load Washer
Maytag top load washing machine model PAV 2300 AWW. I've put in new springs but washing machine gets out of balance very easily. Have you got any suggestions?
If you have replaced the spring is the tub over to one side not in the center of the hole there is what they call a snumber ring on the bottom of the base the washer sets on that could be wore out but it is really hard to replace and you will need a special tool to compress the break
Apr 11, 2009 | Maytag Washing Machines
Knocking sound in the spin cycle off balance.
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Feb 05, 2009 | Maytag Washing Machines
Maytag top loader stopped during spin and now won't start.
ok check the lid switch,,did it knock it out of place,,unplug and take back off ,,,
Jan 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
205 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
