Question about Acer Aspire 4520 Notebook PC
Screen problem my monitor screen problem, mothrboard is ok so wats d problem? is it the monitor or something else? please dont tell me the montor bcuz its too expensive...
  • 476 Answers
Have a look at my link on LCD Screen Replacements
http://www.fixya.com/support/r4540660-replace_acer_laptop_lcd_screens
Hope this helps and please rate me thanks
MISTERDJ
Posted on May 07, 2010
Envision en-7500
yYou dont unless you have a dedicated tuner that outputs to DB9 (VGA plug) or HDMI. Older flate screens dont Do HDMI natively so you would have to get a stand alone tuner like this: http://www.google.com/products/catalog?q=VGA+tuner&oe=utf-8&um=1&ie=UTF-8&tbm=shop&cid=16346340210151671120&sa=X&ei=gEiAT9viBuGciQKD3a3AAw&ved=0CFIQ8wIwAA
Apr 07, 2012 | Computers & Internet
I have a computer that i run dual montors on, both plug into the same video card, both monitors are crt's. my video card has 1 vga connector and 1 dvi connector. so i use a dvi to vga addaptor. now...
It is possible that you've got the resolution and vertical refresh rate set too high. CRTs tend to flicker if the vertical refresh rate is not set to about 72 to 75 Hz. If your screen resolution it set fairly high compared to what the monitor was designed to display it can overtax the video sweep circuitry in the monitor. If possible check the manufacturer's specs.
Often the video driver will let you specify different resolutions for primary and secondary monitor. If you can't find the manufacturer's specs it would be prudent to pick a less demanding resolution or vertical refresh rate for the secondary monitor.
Aug 10, 2011 | Computers & Internet
Have put on a reversing camera and it work a treat. Only problem is that as soon as I start to move backward the pitcher disappears. Is there something that can be put into place so that it stays on??
you can not view a screen while your driving its against the law. there is a wire that is connected to your shifter that tells the monitor to turn off and on. find that wire and ground it and the montor will stay on all the time. why would you want a rear camera on all the time anyway?
Sep 06, 2010 | Blaupunkt Car Audio & Video
My system date is automatically changing to jun 2002 please tell me wat is the problem
Hi, your mothrboard battery needs replacing, cost about £3 to £4.
Hope this helps
Jul 15, 2010 | Mercury P4VM800M7 Motherboard
The monitor will come on but screen do not show.
The picture on your monitor won't come on because the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix yourself.
Good luck.
Apr 15, 2010 | HP W2007 LCD Monitor
Flatron LCD Montor to a Dell Dimension XPS T500
> out of date?
Are you sure that it is "out of DATE" ???
Reconnect your old monitor.
Set the screen-resolution to 800-by-600 at 60 Hertz.
Shutdown.
Connect the new monitor.
Reboot.
The new monitor will be detected, and will run at 800 by 600 at 60 Hertz.
Change the screen-resolution to some higher value that both the new monitor, and your older video-card, will allow.
Jan 02, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
1707FP MONITOR WON'T TURN ON. CHECKED ALL POWER SUPPLY, ALL OK. ON BUTTON WON'T DEPRESS
Generally this doesn't happen with Dell, I f you arn't using DLC or UPS there are chances of circuit break down in the display unit.
Jul 02, 2009 | Dell 1707FPv Monitor
Red colour missing
hello
red colour if missing from mother board then you can fix it from graphics properties of your mothrboard driver
but red may also due to monitor,there should be black colour appeaqrs on screen instead of red.
to solve this you have to take your monitor from where you have purchased
if it is in warranty or gurantee then dont take to third party
the fault in monitor may be due to
fault in monitor cable
also check that cable is not loose
try to plug the cable on cpu again
another fault is inside the monitor
also try to on monitor using detaching monitor cable from cpu,message come on monitor ,if in that message red colour appear,then monitor gun is ok
and problem is in monitor due to desoldiring
if you know about soledring than you can fix this problem yourself only if you know otherwise take it to shop from where you sold it
Nov 22, 2008 | Intel D101GGC Motherboard
LG fLATRON 17" MONTITOR
please specify what type of marks was present on your screen! was in from permanent pen?
Oct 31, 2007 | LG Flatron F700P 17" CRT Monitor
Ummmm, I dont know wat tooh do!!
Well if decide to stick with 360 pick up used units at gamer stores and pick up the warranty for the one year guarantee: anything goes wrong and they hand you another.
Aug 12, 2007 | Microsoft Xbox 360 Console
Open Questions:
Acer Aspire 4520 Notebook PC Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
