Question about Samsung LN-S4692D 46 in. LCD HDTV
I have a Samsung LCD LNR408DX/XAA when I go to turn on my TV it sounds as if the TV turns on but its just a black screen. I tried changing the channel and it blinks but doesn't display any channels or text. I've already opened up my Samsung to inspect any visual internal damage to caps or any other components and I don't see anything wrong. Could this still be signs of a bad power supply or a digital video board?
I am now having this same exact problem.
Apparently there are 4 boards that can be the issue. BUT you must bring it to an Authorized unauthorized service center to resolve the issue. I brought mine to an unauthorized service center and they can not buy the part. My particular issue is a TCOM board on the back of the display which only authorized dealers can buy. In fact if an Unauthoirzed dealer calls up the J&J Samsung parts distributor J&J doesn't even have it their parts inventory so as far as they know the part doesn't exist. which it does you just need to call an Authorized part dealer in your area which you can get the number from 800 SAMSUNG
There are 4 boards unauthorized service centers are allowed to sell 2 PC BOARDS
1 POD PCB
1 Power PCB
When you call Samsung get a CLAIM nuber...
WHAT A PITA
Posted on Aug 13, 2010
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung LNR408DX/XAA Won't power up. Sound works but as far as the screen, no input/source works. After it died I noticed that the screen was very hot especially the upper Left side. In the dark, the...
It sounds like this is a problem with the inverter boards on the LCD panel. Unfortunately the inverter boards are usually only available with the whole LCD panel and the only way to fix it is by replacing the whole LCD panel. This is the most expensive part of the TV (about $1000) and you will need to take the whole TV apart in order to replace the panel. A new TV of similar make and model will usually be about the same price as the repair.
Nov 09, 2009 | Samsung LN-R408D 40 in. LCD HDTV
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
Tv has no picture
TRY NEW JACKS AND OTHER INPUTS
May 15, 2009 | Samsung LN-R408D 40 in. LCD HDTV
Samsung LCD TV HCP4363WX/XAA Black screen no sound.
check out the link below ... sounds like a similar problem:
http://www.dslreports.com/forum/r20889230-Samsung-LCD-TV-No-Picture-but-has-Sound
Aug 21, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung LNR408DX/XAA Wont power up
I had the same problem with a 52" Samsung LCD. I found 2 electrolytic caps with bulging tops on the power supply board. (see pic). I looked to be the 5v section but I'm not sure. I got replacement at Fry's for $1.90 each. All is well!
Ahwatukee Al
Mar 07, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-S4692D 46 in. LCD HDTV Logo
312 people viewed this question
Jerry Greenberg
Jerry Greenberg
