Question about HP Pavilion dv6000z Notebook
I have an Hp Pavilion DV1000, I formated the drive to get rid of windows and install Ubuntu Linux, this worked fine until I wanted to reinstall windows again, Code Purple, and you know what that is, I have read heaps and to no avail as the recovery partition has been deleted, is there a way back from here, besides its my machine I should have the right to install, delete, and reinstall, or format whatever I like without HP telling me what I can, and cannot do and making my laptop into a bookend of no value. I need help. thanks from Never Buying HP Again.
  • 79 Answers
Hi i am an Ex Hp tech. this issue will not get resiolve by doing a recovery. ALL Hp computer do a thing called "Tatto in motherboard" when that comes off you get a code red problem. Now if your laptop is under warrenty then you will have no problems you have to get it benched by them. Assuming your laptop is not under warrenty what you can try is installing a different version of windows. Please let me know if it worked othervise we'll try different steps
Posted on May 07, 2010
  • 185 Answers
I believe this is an older HP model so I have a few questions before I tell you what I would do. Did you get a set of recovery CD's when you bought it? if not did you create them from within Windows?
ok older modes used to come with a set of DVD's where your operating system was stored for if you WANTED TO RE-INSTALL LATER so look for those that would be your best bet. If you did not get those cd's then your PC came with an option to create them that is a way for companies to save millions on dvd's because you would have to buy them and then burn them. if you did not create them then....... we have a problem because what you have to do is get a cd to re install the OS then get a program that is called JellyBean and change the serial number to the one on your laptop, that works mmm 75% of the time because you are installing someone else's OS but then you are making it legal when you change the number to your own. If you don't have the cd then you have to get a copy to install and forget about the recovery partition that is gone you cannot go back using that anymore. Maybe next time you do that you want to install the 2 OSs on different partitions so you can use either one and remove either one without damaging the other
PS. you have to reformat your drive again
if it works for you don't forget to rate me
thx
My hp pavilion dv1000 windows xp the sound drive is not working
You need to reinstall the drivers for your sound card from the CD that you have got with the Laptop.
Mar 26, 2011 | HP Pavilion dv1000 Notebook
Hp 1000 notebook wlan
Yes you will need driver / software for it, what wireless adapter you got?
Oct 04, 2008 | HP Pavilion dv1000 Notebook
I'm having problems with the audio for my hp dv6929wm laptop. Windows does not detect and audio device and everytime i go to update the drivers the installation stops because it can't detect and audio...
If you've ensured the correct services are running and the correct drivers are installed/attempted to be installed, I'd say there's a good chance you're experiencing a hardware problem. The easiest way to test that is w/ a Linux Live CD or to perform a factory OS reinstallation. If you don't want to restore the the computer, try booting a computer up w/ a Ubuntu install cd, and try running the OS live (w/out reformatting/installing the OS), and test the sound. I recommend Ubuntu because the driver support is pretty good. With that said, if it doesn't have the correct sound driver for your hardware, this solution will not help us out, so at that point, I'd recommend reinstalling Windows and see if your sound works. If it doesn't work after the OS reinstallation it's a hardware problem.
Mar 25, 2011 | HP Pavilion dv6000z Notebook
How to Install both XP and Linux?
I would install XP 1st then Open suse or Ubuntu. When you install either of these linux OS's ensure you install to another partition other than the windows one. Both installation routines will allow you to format the drive to the linux ext2 format and automatically install a boot manager (usually GRUB) which will allow you to select the OS you wish to boot.
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
Drive L: ?
So you've got rid of the ext partition but windows keeps displaying the mapped drive with and an error? Now you want to remove the wrong mapped drive.
Depending upon the software driver you installed - FS Driver, Explore2FS, you will probably need to uninstall that driver (it should be under Add/Remove in Control Panel). In some versions of FS Driver, I think it actually has it's own preferences under control panel which you can disable the mounting in.
May 05, 2009 | Dell Dimension 3000 PC Desktop
I cant format my hard drive...
If you want to eliminate the recovery partition, my favorite method is to get a copy of Ubuntu and use it in live mode to access 'gparted' which is a good simple partition editor. If you have access to another similar method, like Partition Magic, that should be perfectly fine. Once you get the whole drive set up as one, I imagine XP should be quite happy. Unless that old drive is having other issues... (I'd probably throw 'smartctl' at it while I was in Ubuntu to see if there were any obvious impending failures.)
Feb 23, 2009 | Compaq Hard Drive SCSI 73GB 15000RPM...
Do i need to change my harddisk?
It sounds like UBUNTU formated your hard drive where xp does not reconized the drive. When you go into BIOS setting, do you see your hard listed? If so, you should be able to put a clean install of XP to the drive. When you start the install, you must select REFORMAT drive and install XP. If this still fails, you may need to fdisk your drive first using DOS command and reinstall XP. Let us know if you incounter any more problems after doing this. Good Luck.
Feb 08, 2009 | HP Pavilion dv6000z Notebook
HP DV1000 notebook
email me if you still need drivers <i have them princesaazul2000(at)hotmail(dot)com
Aug 03, 2008 | HP Pavilion dv1000 Notebook
HP Pavillion ze5600 notebook won't boot up
Try booting, hit F8 for the list, go to safe mode but right after you hit enter to go into safe mode hold the left and right <ctrl> keys. That loads minimal amount of drivers as possible. Do you have you Win XP disk in case a repair is needed? Let me know what happens.
Apr 14, 2008 | HP Pavilion dv1000 Notebook
Installing cd
you can use any xp disk to format hd and reinstall .
do u not know anyone who could lend u their copy for a few hours.make sure u have the cd key.
you can use the same disk many times on many machines with the same disk n same cd key.
Apr 06, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv6000z Notebook Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
