Question about Cub Cadet Lawn Mower Deck Drive Belt Replaces CUB CADET 75404044 CUB CADET 95404044
Cub Cadet LTX 1045 deck rubs R rear and L front tires
Struck front of tractor with tree. Deck leading edge rubs against front left tire and trailing edge right rear tires. Need to turn deck counter clockwise as seen sitting on seat. Height and side to side ok. Front end appears OK. Left turn can put front left tire under leading edge of deck. Deck lifted up will spin right side anti-scalp wheel against right front tire.
  • Scott Froid May 07, 2010
    Second line make that rear tire, not tires. 46" deck, compared to showroom, front end looks ok.
5 Suggested Answers
  • 133 Answers
SOURCE: CUB CADET
Look under the battery holder. There is alot of wires that come down from the ingition and the fuse should be mounted or fastened right under the battery holder.
Posted on Sep 01, 2009
SOURCE: Cub cadet LTX 1045 steering problem......... Only
Probably a bent "drag link". See your owner's manual about checking for damage adjusting the steering. For the LTX 1045, it is "Maintenance Section 6", Page 22. If it is bent, repair or replace as mowerman1857 indicated.
You should also lubricate at the two grease fittings (per side) shown on Page 20 -Lubrication - "with a #2 weight Multi-purpose grease". It may have been skipped at the factory or may have been stored at high temperature before you got it, and dried out. (Text in quotes are from the manual)
Posted on Nov 01, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
SOURCE: cub cadet LTX 1045. The PTO cable came off the
how does p t o cable go on a ltx 1045 cub cadet
Posted on Aug 31, 2011
Have a 1045 ltx cub cadet lawn tractor,belt for deck keeps coming off when disengaging?
be sure the belt guides are in place. they hold the belt in so the belt wont fall off when not tight or at an angle.
Jun 29, 2017 | Cub Cadet Garden
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Will a wiring harness from a ltx 1045 fit a ltx 1050
Since the LTX1050 has an electric PTO and the LTX 1045 has a manual PTO then I would say no.
May 10, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
Cub cadet troubleshoot
check make sure all tires have same tire inflation
Aug 24, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
How do you replace the deck engagement cable on a cub cadet ltx 1040
there is a pin,like the ones that hold the deck on,on the end of the cable,pull it up and off to get the cable out,
Aug 11, 2012 | Garden
Cub cadet ltx 1045 when turn left right wheel just slides does not rotate
are the tie rods out of adjustment and the tire rubs on the frame or is something bent
May 08, 2012 | Garden
Can you use Fix a flat to repair a flat tire on the Cub Cadet LTX 1042
If it's a simple puncture, "Fix-a -Flat" or another product called "Slime" might work for you. I believe Walmarts sells both.
Hope this helps... Good luck!
Oct 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Lawn Mower Deck Drive Belt Replaces CUB CADET 75404044 CUB CADET 95404044 Logo
285 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
