Question about Canon PIXMA MP780 All-In-One InkJet Printer
When i try to scan it says "can't open driver"
    Brigadier General:
  • 4,090 Answers
Uninstall and reinstall the software make sure you have the latest software updates These can be obtained from canon website once you have entered you model in the search. Dopwnload of drivers and software is free
please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
How to scan from a lexmark x342n to my laptop.
Firstly, download the drivers from this location:
http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X342N&focusedTab=DOWNLOADS#1
Specifically this one:
Local scan driver for multifunction printers X34x
After you have installed it you should see the device under Control Panel> Printers> Scanners and cameras
Mar 09, 2011 | Lexmark X342n All-In-One Laser Printer
I'm trying to scan and can't find a program to open?
Do you have the scanner driver installed? The scanner needs the driver to be able to communicate with the computer.
You can download the scanner driver (and other software) from HP here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1153494&lc=en&cc=us&dlc=en&lang=en&cc=us
Once you install the driver, you can view the scanner's properties from your PC and determine if there is another problem preventing you from scanning.
Jun 18, 2010 | HP Photosmart C6180 All-In-One InkJet...
My scan button does nothing. How can I scan?
When you press the "scan" button on the lexmark, the scanner is trying to connect to a specific software program that in this case you may not have installed.
You will want to try to test the scanner driver directly.
For windows XP and Vista, try the following.
1. Open your start menu
2. Select Control Panel
3. Select "scanners and cameras"
NOTE: for windows Vista, make sure you are in "classic view" to see scanners and cameras.
4. Check whether there is the lexmark listed in this window.
For windows 7, you will need to do something a little different.
2. go to All programs
3. Open "windows Fax and scan"
4. Click on "new scan".
5. Check whether there is the lexmark listed in this window.
If there is no lexmark, you need to check the lexmark website for drivers. If the lexmark is there, try double clicking the icon to run the scan wizard.
Thanks,
Pat
Mar 31, 2010 | Lexmark X2330 Printer
Hp F4280 doesn't work in scanning
if your printer is able to copy that means there is no problem with the printer hardware
so when you try to scan you might get some error message if you can provide the error code it will be easy to proceed
however you can also try the following steps and check the scanning function
on desktop you will find the hp solution center icon right click on it now go to properties it will open a new window now if it is xp click find target for vist click open file location now in this location find HPQSCNVW OR HPISCNAP double click the file and see if it scans if it dose you can create a shortcut of this file on desktop
if you dont fine these files then the software was not installed correctly so try n reinstall the printer driver for that insert the printer cd right click and open the cd content and look for Util folder now open it and click on the ccc folder in ccc you will see uninstall L3 open and run the uninstall restart the computer and then install the driver again
hope this will help you
Aug 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
Can't calibrate the scan before scanning
I had the same problem when upgrading to mac os x. I was trying to scan directly from Photoshop but got the calibration message. I tried the two solutions given at the Canon website but they didn't work. I ended up downloading the Toolbox application to scan directly from there but the same message appeared. After installing the Toolbox application I unistalled the driver (11250) and reinstalled it. I opened Photoshop and tried scanning and the calibration window appeared only this time it didn't stop to give me the "Flim Adapter" warning. I must point that the scanner lid was open when this happend but I'm not sure that had anything to do with it.
So apparently it works if you have the Toolbox installed prior to installing the driver. The driver, Toolbox application and unistall driver can be found at Canon's website. Hope this helps.
Ciao!
Jun 02, 2009 | Canon CanoScan LiDE 500F Flatbed Scanner
Microtek Scan Master 5900 hrdware error -3
Code 3 The driver for this device might be corrupted, or your system may be running low on memory or other resources. (Code 3)
Here are some things that you can try to resolve this problem.
Close some open applications
If the computer has insufficient memory to run the device, you can close some applications to make memory available. You can also check memory and system resources, and the virtual memory settings.
  • To check memory and system resources, open Task Manager. To open Task Manager, press CTRL+ALT+DELETE, and then click Task Manager.
  • To check virtual memory settings, right-click My Computer, click Properties, click the Advanced tab, and then click Settings in the Performance area.
Uninstall and reinstall the driver
The device driver may have become corrupted. If the driver is corrupted, uninstall the driver from Device Manager and scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Install additional RAM
You may have to install additional random access memory (RAM).
May 21, 2009 | Microtek SCANMAKER 5900 Flatbed Scanner
Scan and export to file
Please follow these steps :-
1- try to scan the image in MS paint.
just open mspaint by the RUN command.
click on FILE and select FROM SCANNER AND CAMERA
then try to scan.
2- Try to restart the scanner service from the services.msc
restart the system.
or
try to restart the system in safe mode then try again to scan the document.
press F8 for safe mode while reboot the system.
3- Try to delete scanner from the DEVMGMT.MSC
just click on scanner in the list and delete that.
it can be in USB list.
restart the system
or
4- Try to uninstall scanner's driver from the DEVMGMT.MSC
just type DEVMGMT.MSC in RUN command
then select the scanner from the USB device and right click on the scanner and try to uninstall driver.
then install driver from the cd or internet.
May 07, 2009 | Canon CanoScan LiDE 500F Flatbed Scanner
Using hp scanjet 3970 Just loaded hp scanning software and the large install of the 3970 drivers. When I enter the program the scanner opens and scans te image on the tray. (I am trying to scan a...
Have you checked the cord from the scanner lid to the scanner base. if that doesn't work I would try uninstalling the scanner and then reinstalling it. It sounds like a problem with the twain driver for the scanner.
Dec 20, 2008 | Computers & Internet
Scanning
Dear Tony
My problem is i have used a printer "Hp psc 1210 all in one" in my old computer under windows XP, the scanner was ok!
Recently I changed a new computer "HP a1730n" it uses Windows Vista and vista suggest use Photo Gallery to scan but can't edit the the scanned text document.
Please give me some help!
bhca1704
Dec 04, 2007 | HP PSC 1210 All-In-One InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
