Question about HP Computers & Internet
Can't connect to a wireless network
I can't connect to a wireless network if my battery is in the laptop while plugged into a wall outlet. I can connect if one of the two is not present. I've already reinstalled the wireless driver over the old driver, restored the computer to an earlier time, and even deleted the driver and reinstalled it. Also, it also does it in safe mode too. My computer is a HP TouchSmart tx2-1377nr and the wireless card is a Broadcom 802.11b/g WLAN. No, it does not give me an error so there is no error code for me to give and it just says it can't connect. Any help is appreciated.
  • HP Master
  • 3,247 Answers
It is likely the problem is with the battery or the charger.
It is not provding the correct supply to let the laptop work.
You will have to check if the charger circuit on the laptop is working properly. Buying a new battery might solve it but an expensive experiment.
Won't be a cheap solution unless you are lucky and get one on loan.
Posted on May 07, 2010
2 Suggested Answers
  • 902 Answers
SOURCE: I have a HP Probook
you will need to go to a linux forum and ask the question there i have found a few on there site for ubuntu drivers.
but here is a direct link to the driver download try this first http://www.broadcom.com/support/802.11/linux_sta.php
Posted on Mar 15, 2011
How can I enter password in roku 3 I don't know how it connect and not work
I have created this document that will step you through the setup and also enter your password for your network. Hope this helps you.
Follow these steps to setup your Roku player 1. Connect to your TV
  • Use a HDMI cable. Connect one end to the HDMI port of the Roku player, and the other end to an available HDMI input on your TV.
  • Make note of the TV input used.
2. Power up key components
  • Open the battery compartment and carefully insert the provided batteries into the slots, following the correct battery orientation.
  • Power up the Roku player by connecting the provided power adapter to the Roku player and to an available wall outlet.
  • Turn on your TV and select the correct TV input.
3. Connect to your network
  • If you are using a wireless network, select "Wireless" as your network connection:
  • Select your network from the list of available networks.
  • Enter your wireless network password when prompted. (Note: passwords are case-sensitive)
  • If you are using an Ethernet wired connection, select "Wired (Ethernet)" as your network connection.
4. Complete guided setup
  • Get the latest software
  • Your Roku player will let you know if there is a software update available, and will restart after the update
    is complete.
  • Link your Roku player from any Internet browser
  • A link code should be displayed on the TV screen after restart
  • Using an Internet browser, follow the instructions to link your Roku player to a new or an existing Roku account.
Help for common setup mistakes and solutions
Symptom
Possible causes
Try these!
I don't see any picture on the TV
TV is OFF
Cable loose
Roku is OFF
Wrong TV input
Ensure TV is ON (it's more common than you think)
Check all connectors are snugly in place
Check power adapter is snugly connected, and wall outlet is working
Select the correct TV input
I can not connect to wireless network
Weak wireless signal
Wrong wireless name
Wrong wireless password Wireless name hidden
Move Roku player location (even a few inches may help)
Ensure correct network name selected
Ensure correct password entered
SSID can be hidden, use "Add Network" from wireless network screen
My remote does not work
Not in line of site
Batteries weak
Get closer and ensure there are no obstacles between your remote and the Roku player
Try a fresh set of batteries
Resolving wireless connectivity
If your Roku player isn't connecting to your wireless network, try the following:
Description
Do this
Tips
Repeat guided setup • •
Go to Settings>Network>Wireless•
If "Update connection" is available, select it to refresh your connection
If not, just select your wireless network from the list, enter your wireless password when prompted
If you were previously and just lost connection, you may not need to enter your password again
Passwords are case-sensitive
Restart the Roku player and • your wireless network
Unplug the power connector from • the back of the Roku player
Unplug the power connector from the back of your wireless router
Unplug the power connector from the back of your modem
Plug the power connector back into modem (wait a couple of minutes for it to fully boot)
Plug the power connector back into the wireless router (wait a couple of minutes for it to fully boot)
Plug the power connector back into your Roku player, and wait for the image on your TV
Follow repeat guided instructions above
Your wireless router and modem may be combined as one device
Factory reset the Roku player
From the Roku home screen, sele•ct Settings>Factory reset and follow the instructions
Note: You can also reset the Roku• player using the reset button. Find the reset button on your Roku player, press and hold for 15-20 seconds ( the front LED will rapidly blink a few times)
Factory reset should be used as the last resort, if all other steps failed to recover functionality
After a reset, you will need to relink your Roku player to your Roku account, and setup subscribed channels with username and password, if applicable
If you forgot your password, you can recover it here at this URL:
Forgot Password
A new password will be sent to the email account listed in your account. If you do not see the email, be sure to check your spam filter.
Sep 12, 2014 | Computers & Internet
Tip
Laptop will not turn on, laptop will not power on, laptop will not start
Make sure your laptop battery has a charge. Plug it into the wall outlet for 30+ minutes and then try powering it on. When you plug it into a power source, usually the laptop will have a light indicating that it is charging. Look for a light. If the light does not light up, try a different wall outlet. <br />If it still does not charge, you may have a bad power cord, a bad laptop battery, the wall outlet may be bad or the laptop itself is damaged and will need to be serviced by a technician or replaced.<br /><br />Through the process of elimination you can narrow down possible causes.<br />-Try a different wall outlet(or by testing another device make sure the wall outlet is good)<br />-Try a different power cable.<br />-Try a different laptop battery.<br /><br />If none of the above help then you may need to have your laptop repaired(internal damage) or replaced.<br /><br />If your laptop is under warranty you should contact your laptop manufacturer or warranty policy holder to have it repaired or even replaced. <br /><br />If it is not under warranty you should look for local computer repair shops or technicians. <br /><br />-G33k<br />
on May 22, 2011 | Computers & Internet
Dell Inspiron 5720
F-8 is the key, Try to "cold start" the computer, meaning remove the power plug from wall outlet or uplug from computer, remove battery, now replace battery and plug computer into wall outlet. Push the on button while "TAPPING" the F-8 key repeatedly Tap, tap, tap, until you hear a beep or it load the black menu with safe mode options. IF THAT DOES NOT WORK: shut down the laptop,remove AC supply, remove battery. Plug the AC power back in,DO NOT INSTALL BATTERY, Start the machine, without battery installed, and tap F-8 repeatedly. If it still fails, PULL THE PLUG OUT OF THE WALL OUTLET WHILE THE COMPUTER IS STILL RUNNING. NOW PLUG THE LAPTOP BACK INTO THE WALL AND START, THAT SHOULD TAKE YOU TO A BLACK PAGE WITH WHITE SCRIPT WITH OPTIONS YOU ARE LOOKING FOR.
Oct 31, 2012 | Dell Computers & Internet
Http://192.168.0.1/
286520a4-ee13-4d09-80b0-c6808ea917d3_15.pngA modem and router properly plugged in
  1. Plug the modem into an electrical outlet.
  2. Plug one end of a phone cord or cable into the modem, and plug the other end into the wall jack. (DSL users: Do not use a DSL filter on the phone line.)
  3. Plug one end of an Ethernet cable into the modem, and plug the other end into the wide area network (WAN) port on the router.
  4. Plug the router into an electrical outlet.
  5. Plug one end of an Ethernet cable into the local area network (LAN) port on the router, and plug the other end into the networking port on the computer that you want to connect to the Internet. (If you are connecting wirelessly, skip this step.)
  6. Start (or restart) the computer.
  7. Open the Connect to the Internet wizard by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, clicking Set up a connection or network, and then clicking Connect to the Internet.
READ http://www.fixya.com/support/r7900574-general_router_setup
Nov 26, 2011 | Computers & Internet
How to retrieve password from wireless access point router zyxel -570u
Initial Set-Up
Plug your wireless router into the cable connection in your wall. Plug the connection cord into the "WAN" port on the router. Plug the router's power source into the wall and turn the router on. Connect your wireless access point to your router by pushing one end of an Ethernet cord into the WAP. Push the other end of the Ethernet cord into the "LAN" port on the router. The WAP connects your wireless devices to your router.
Connect your laptop or computer to the WAP. Click the "Start" button on your computer and then click "Control Panel." Click "Network and Internet" and then select "Network and Sharing Center." The "Network and Sharing Center" window opens.
Click "Set up a wireless router or access point." Click the "Next" button.
Follow the prompts to create a wireless pass phrase or security key. Write the key down in a safe location to ensure access later, if required.
Aug 30, 2011 | Zyxel ZyAIR G-570U - Wireless access point...
I have just bought Belkin Powerline AV starter kit. I have a Belkin N1 Wireless Modem Router connected through a Carrier PoE adapter. I have tried to connect my Sony TV and PS3 through the powerline units...
Try reset the device and start a new configuration.It seems that your networwork have issues between the router and the powerlines.All need to be in the same network as per router configuration.Connect one adapter to your router and plug it into an available electrical outlet. Plug the second adpter into an available wall outlet and connect the other end to any device with an available Ethernet port such as a gaming console, set-top box, or computer.
pd: OS to use the adapters; Windows 2000, XP or Vista.
Feb 24, 2011 | Belkin Powerline F5D4050 Network Adapter
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Dell 9200 laptop will not load. When I power it up it flashes the cap lock key and shuts down.
Is this a new laptop? If so make sure that the AC power source is plugged into the wall, this is a common issue with new and old Dells, the connection from the labtop gets loose and needs to be pressed. However when the power is low in the battery it will act like this. Make sure the battery is fully charged and the laptop is plugged into a power outlet from the wall.
Sep 03, 2009 | Dell Inspiron 9200 Notebook
Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
Apr 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Keep getting disonnected from internet when using laptop power cord
weird problem you got there huh, just try to reinstall the wireless or built in lan card driver, is the power adapter near the lan cable outlet? maybe its just loose, try to use wireless connection in the internet
Apr 05, 2008 | Computers & Internet
Computers & Internet Logo
98 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
