Question about Dell Inspiron 1420 (dncwja1_1) Intel Core 2 Duo T7250 (2MB cache/2.0GHz/800Mhz FSB) 80GB/1000MB PC Notebook
I have an active internet connection. in fact, my pc works with this connection.. i tried to connect my laptop to the internet, but it didn't prompt as it usually do..it used to show the sharing icon on the lower right hand side.. i tried to look for it, but it isn't there anymore..what should i do
  • Dell Master
  • 3,247 Answers
Hard to answer your question without knowing what Operating System you have on your PC and laptops connections, eg. LAN, wireless etc.
If you have windows XP you will need to check Network Connections on your laptop to make sure the Internet connection is showing as connected.
Click on Start - Control Panel -- network connections.
Check if Internet gateway is setup
If not go to Internet Options in Control Panel and setup the Internet connection using the right buttons.
I cannot guide you if you have Vista or Win 7.
Posted on May 07, 2010
Dell vostro laptop wifi connection
First Step, Reboot your PC.
Second, try connecting an ethernet cable to test if it is a network fault. If that fails, then Click on the start button, then select run (If there is no run box, simply type in the search box) and type cmd
You will get a black command prompt screen. type ping www.google.com
If you get any replies with packets sent 4 lost 0 it means that the internet is active but there is a problem with Windows.
In this case, try reseting your Internet browser.
If that does not work, do a small Winsock, by following this :
Then type netsh winsock reset
Reboot your PC, that should work.
If that Fails, get a local tech. (You may need to reinstal Windows Eventually)
Nov 20, 2013 | Dell Computers & Internet
Tell me how to connect internet from mobile i009 to bluetooth?
At first call to your customer care executive to send you for internet settings for your mobile. When you recive the settings then do the following things-
  • Install the settings first.-go to your message inbox and find the settings message when you open it then get the install option. Just click on install option.
  • Select your internet profile-just go to your internet menu and select settings. After that select Internet Profile and select GPRS option like Airtel Gprs/ Mobile Office if you are Airtel user.
After that Install Pc-Suite and
  1. Activate Bluetooth on your mobile phone (usually found under the Settings menu) and set it to be discoverable or visible.
  2. On the PC, find your Bluetooth program manager (in Windows XP and Windows 7, look under My Computer > My Bluetooth Connections; in Vista, look for Bluetooth devices in the Control Panel; on a Mac, go to System Settings > Bluetooth).
  3. In the Bluetooth program, select the option to add a new connection or device, which will make the computer search for available Bluetooth devices and find your phone.
  4. When your mobile phone appears, select it to connect/pair it to your laptop.
  5. If prompted for a PIN code, try 0000 or 1234 and enter it on both the mobile device when prompted and your laptop.
  6. When the phone has been added, you will be asked what service to use. Choose PAN (Personal Area Network). You should then have a working Internet connection.
May 18, 2011 | Computers & Internet
I have a dell inspirion with vista and I can not connect to the internet using a cable modem.
Have you tried disabling your firewalls, f it came with norton 360 or norton internet security remove it and then try connecting if you can then its your firewall stopping it
another way to try without uninstalling is to click on the start button then in the search box type CMD and press return
in the command prompt that opens type
ping www.google.com and hit enter
if you get four packets sent and four received your firewall is blocking the internet connection. Remove it try the internet if it works reinstall it and it will detect the new network and allow you access.
type ipconfig in the command prompt window and hit enter if you get a 169.x,x,x x=any number then the laptop has no ip. Make sure that the network card isnt disabled
if they all fail and the laptop hasnt got an ip address, then the problem is the cable modem, is the internet active? I.e. you can plug it into another pc and it works
Oct 30, 2009 | Dell Inspiron 1501 Notebook
Computer windows problem
Once a WIndows install is prompting for activation, you'll need to connect the system to the internet, and enter the PID during the activation process. Once you run the activation tool and the activation is validated, your system will return to normal.
Windows must be activated.
OEM installations of Windows (Boot to an OEM branded Windows CD EG: DELL for a Dell System) are pre-activated thru the BIOS and will only work on authorized OEM branded systems. On non-OEM systems it will prompt for activation and will not activate.
Sep 01, 2009 | Computers & Internet
When trying to connect to my Q-see system via internet I get DVROcxEx.cab ... Connect fail! Have any clue what I should do to fix the issue... I have ActiveX set to enable on everything and I have Security...
i had same problem, this fixed it. internet explorer. tools>internet options>security>custom level> Under active X controlls and plugins, make sur they are all enabled or prompt. there are like 4 of e u have to change.
Jun 15, 2009 | Internet Q See Ufo CCD Camera
Cant connect using any browser,appreciate your help,
make sure your internet connection is hooked up
if its not your internet connection try upgrading your internet
Jan 06, 2009 | Toshiba Satellite A100-S8111TD Notebook
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
Help active sync will stay in limbo attempting to connect to cradled axim
Does your system detect the handheld? After you connect the cradle or cable to the computer, then you should be prompted to install drivers for the handheld. Make sure that Dell Pocket PC appears in the Device Manager.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
See all Dell Inspiron 1420 (dncwja1_1) Intel Core 2 Duo Questions
Dell Inspiron 1420 (dncwja1_1) Intel Core 2 Duo T7250 (2MB cache/2.0GHz/800Mhz FSB) 80GB/1000MB PC Notebook Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
