Question about Maytag EPIC MFW9700S Front Load Washer
How do I clean out the drain - Maytag EPIC MFW9700S Front Load Washer
  • 5,911 Answers
If you need to clean out the drain pump reservoir, the following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and any problems persist, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage these small drain pumps. If any error codes are generated, it is caused by the drain cycle exceeding 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
NOTE: Maytag Epic is manufactured by Whirlpool, so these instructions will apply.
Posted on May 07, 2010
My washer drains to fast it overflows my drain
use a drain cleaning product to clean the blocked drain or get in a plumber to do the job
it is not a problem from the washer but of drain maintenance
Oct 22, 2017 | Washing Machines
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
Clean the drain screen
It is best to keep your drains clean. Simply put. If you want to clean that drain screen, you can remove it. I suggest using vinegar to sanitize it. That way you don't run the risk of wearing down the finish.
Elisa Jed ' http://www.mcdermottplumbing.com/sewer---drain-cleaning-service.html
Apr 09, 2014 | Miele Premier-Plus Built-in Dishwasher
Oe code. Will not drain. Steps to fix?
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
I am getting an OE code on my dishwasher
Hi
Daniel
Aug 24, 2011 | LG LDF6810ST Stainless Steel Built-in...
0E is showing on the screen. Can you please advise what this means?
Hi
Daniel
Aug 01, 2011 | Dishwashers
I have the Kenmore Elite HE3t and the control panel lets me change the settings but the door stays locked and the drain pump (off the filter) keeps going but there is no water to drain...cleaned drain out...
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please check this video for cleaning:
Hope this helps... Please post back if you need more information.
Daniel
Mar 31, 2011 | Kenmore Elite 45986 Front Load Washer
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    Taking too long to drain
    if it is taking to long to drain then this is a sign that something is plugging up the drain line.
    remove the drain plug and clean the drain screen -- this will be right next to the pump body.
    as soon as it is clear, the machine should be draining great.
    if you are still having troubles after you clean the drain line -- then there could be a problem with the drain pump and it might need to be replaced,,,, but clean the line first as this is the most common problem.
    c...
    Feb 10, 2011 | Kenmore Energy Star 44092 Front Load...
    Maytag EPIC MFW9700S Front Load Washer Logo
    165 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
