Question about Canon PowerShot A430 Digital Camera
Camera keep on displating
Camera keep on displaying "Please replace batteries". I've tried more than 20 pairs of batteries, all 1.45 to 1.54 charged? Any help?
    Brigadier General:
  • 4,090 Answers
OK try using some steel wool or emery paper (fine) on the terminals inside the batteryy compartement. I suspect there is some sort of corrosion or substance causing poor connection.
Hold the camera so no swarf gets retained in the battery compaertment. Wipe the area clean after rubbing contacts
please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
Camera wont charge. Was for a while but now displaying batteries cannot be charged.
sounds you may have to replace the batteries, but try taking out the battery from the camera and press the power button for about 10 seconds. Keep it turned off without the battery for 5 min then reconnect the charged batteries
Dec 08, 2010 | HP Photosmart M425 Digital Camera
When i plugg in my camera to the computer it wont chrge it wont even turn on if there is a soultion please contact me asap!!!
Hey Sophia,
Have you checked the battery, as the problem seems to be with battery
First of all checked if the battery is inserted properly
Take it off and re-insert it... make sure the +ve and -ve are set properly
If it still does not work...you got to replace the battery
Thanks
Oct 08, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Casio NP20 battery does not charge,charger keeps flashing, does this mean I need new battery? also,it has 700MAH will 800 do when I replace it? was does this mean
If you have had the battery a long time or have charged it often it will need replacing if it does not charge.
800MAH is the capacity of the battery, how much power it can store.
800 is better than 700 and if it is a NP20 it will be OK in your camera.
Hope this helps.
Feb 21, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
NIMH Battery goes off after 20 shots for Nikon Coolpix L01
the camera takes just about any AA pair of batteries ... lithium will give you the most pictures .. your NiMH batteries should last longer unless they are old .. you may have one weak battery ... you can try a pair of standard alkalines to see if there is something wrong with the camera .. if those work ok then you need a new set of NiMH ... there is a new type out called "eneloop" .. they are just like normal NiMH except they dont go dead when you store them .. even after a year they are still charged .. with normal NiMH batteries as they age they will self discharge in 2 weeks or so .. so you have to charge them just before you use them ..otherwise they go dead on their own .. if you charge them then not use them for a week then you will not get nearly as many pictures ... the eneloop batteries fix that .. you can also recharge them many more times than standard NiMH batteries .. they cost about the same ..
Oct 06, 2009 | Nikon Coolpix L1 Digital Camera
NP-20 lithium battery not charging
Buy Ni-cd batteries instead there pretty good.
They are inexpensive, reliable and resist abuse way better than NP-20 because those batteries are poor for high performance applications such as digital cameras.
Good luck
Apr 11, 2009 | Casio Exilim EX-S600 Digital Camera
"CHA" message - will not take picture
believe it is the film card. Try a different one.
Jun 21, 2008 | Nikon D70s Digital Camera
Camera won't turn on.
Mine had the same problem.  I consulted http://camerarepair.blogspot.com/ and it said to use rechargeable batteries only.  The entry claimed that alkaline batteries, even if they're brand new, don't have sufficient power for more than a few pictures and may not even be powerful enough to turn the camera on.  I was dubious, but I tried putting in a pair of fully charged rechargeables and, by Gum, the camera was suddenly working again.  So before junking the camera, try investing 20 bucks in a battery charger and a pair of AA rechargeables and see if that fixes it.
Oct 28, 2007 | Fuji FinePix A350 Digital Camera
Technical problem
I purchased a *ist DS used a couple of weeks ago, and it turns out to have similar problems. This camera seems very fussy about batteries. I am using rechargeable NiMh AAs. After about 30-40 exposures, the camera shows battery depleted. If I turn the camera off, then back on, it will show a charge - sometimes a full charge and will work for another 20 or so exposures. It can keep this up for a couple of days.
I read an explanation in one of the photo blogs (can't remember which) that suggested this was caused by one or two incompletely charged batteries in set of 4. If one is discharged the current from the others supposedly will flow to it, giving fluctuating power readings to the power management curcuit. This sounded plausible enough that I purchased a new charger yesterday which monitors the charge on each battery. Too early to tell whether this solved the problem or not. The other option is to switch to disposable batteries.
Oct 09, 2006 | Pentax *ist DS Digital Camera
Canon PowerShot A430 Digital Camera Logo
156 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
