Question about ASUS Eee PC 701SD 8G Notebook
The notebook just stopped charging, it worked fine until then. Do you think it's the battery or the charger? And where can I get new ones?
  • 3,530 Answers
Try to perform power drain first. Inorder to do this, you have to take out the battery and unplugged the power adapter. press and hold the power button for 30 secs. Put the battery and power adapter back in. power on the computer then checked if battery is already charging. if same issue will occur, then you need to replace the battery.
Posted on May 07, 2010
  • 2,404 Answers
Your going to have to try a new battery first and if a new battery doesn't work then you know its a problem with either the dc jack or the motherboard.
Here is a place for the AC Adapter:
http://www.amazon.com/HQRP-Adapter-Subnotebook-Replacement-Mousepad/dp/B003C0W88W
Battery would be located here:
http://ifuncity.com/Products/2202_Laptop-Battery-For-ASUS-Eee-PC-AL22-703-900A-900HA-701SD.htm
Won't Charge
If it's not a recognized charger it'll stop charging the battery and try to run on the charger alone. If the peak draw of the laptop is higher than the charger output, it'll go right back off.
Try removing the battery and see if it'll boot on the charger alone.
Apr 01, 2014 | ASUS Q200e Touchscreen Notebook
Flashing orange laptop light on samsung laptop
If your battery is six years old, it has done very well and you have looked after it. I would think that a new charger will fix your problem.
Dec 21, 2013 | Samsung R519-53S Notebook
I have a Pride legend three wheeler- I replace the battery charger because it would not charge the batteries. I pluged the new charger into the control module it will charge the batteries. Batteries are...
if I understanding this correctly , you cannot use the scooter why it is being charged, there is a inhibit pin that stops the scooter from being used,
All scooters are designed this way.
Regards
Dec 14, 2012 | Pride New Mobility Legend 4 Wheel Scooter
I have a Satellite A215-S4807. The original battery went completely dead (possibly from this problem), so I just went out and got a new one with a 4800mAh, which is slightly higher than the 4000 it came...
There is something wrong with the "recharger" components on the computer's motherboard.
Instead of charging the battery, and then stopping the charging process, it is "draining" your batteries.
Take your Toshiba to the nearest qualified Toshiba service location, to get it fixed.
Aug 26, 2011 | Toshiba Satellite A215-S4807 Notebook
I bought a Dell Inspiron 1318 about 3 years ago, new. About a year ago my battery stopped taking a charge. I just decided I needed to buy another battery online from BattPros.com. I followed the...
Hi
Check this
When your shut down your computer and plug your the charger in your laptop that time Orange lite is showing on. if no showing then its problem to your laptop
Jun 05, 2011 | Dell Inspiron 1318 Laptop Computer PC...
Cordless drill - model KC9682C - probably 8 years old. Stopped working shortly after a battery re-charge. I'm guessing it's the battery. It charges for a few minutes then the red light goes off. Could it...
If light is on charger the charge is fine. You could verify using voltmeter it should put out = to what it says on the back of charger 12-18 volts or so.
Most likely battery is shot after 8 years they just dont' hold a charge anymore and they often will only charge for a few minutes when the chip in the computer tells the charger to shut off due to defective battery.
compare prices of new drills and new batterys sometimes new drill is not much more. Try ebay and harbor freight for ultra low priced batteries.
Mar 03, 2011 | Black & Decker Drills
Battery will not charge.plugged in not charging
Does the computer start anyway, but it's just that the battery won't charge? If that's the case, it's probably a bad battery.
A procedure to do before assuming a bad battery is to (1) remove the battery, (2) disconnect the power supply from the computer, and (3) press and hold the power button for about 30 seconds. This resets the logic circuits in the internal power handling section. If that doesn't help either, then the battery is probably bad.
If the computer isn't starting, however, it could be that the power supply has failed. Check the voltage output on the power supply.
Hope that's helpful.
Jan 12, 2011 | IBM ThinkPad T30 2366 Notebook
Acer Aspire 5315 randomly stops charging.
I think u just answered urself, replace the power jack should solve the problem
Oct 10, 2009 | Acer Aspire 5315 Notebook
I pod problems
Hi
I think your battery may be going bad or you need to purchase a wall charger to fully charge your battery. Charging your iPod on your computer works fine for a while, but as the battery gets older, it needs more charging and often it doesn't get enough from the computer. Try a wall charger first. Charge it all the way up until it stops charging. If it still shows a low battery you need to have a new battery. There are a lot of places that can do it. Hope that helps.
Dec 20, 2008 | Apple iPod MA446LL/A MP3 Player
Charging Problem
go back to old bios if u can
Jan 21, 2008 | Dell Latitude D600 Notebook
ASUS Eee PC 701SD 8G Notebook Logo
226 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
