Question about Simrad CE44 GPS Receiver
Our water temp is reading incorrect
When at sea our sea temp is incorrect
IT IS PROBABLY TEMP SENSOR IS FAULTY CHANGE IT.
Posted on Oct 17, 2013
South seas spas
need more info. will temp lower? if temp lowers try setting up to 104 if desired temp will not increase sounds like you need temp adjustment switch if desired temp goes up to 104 but water doesnt
sounds like temp sensor if temp sensor is good heater element
Feb 16, 2014 | Pool & Spa
I have a zoneaire sea ptac unit that wont produce heat on the high setting but will on the low setting... would this be a bad capacitor?
Pls note the heat temp that you kept must be 3 to 4 degrees C* between room temp and required temp.
And also number-wise keep down will be high cooling and keep up will be high heating.
Tnx
Nov 15, 2013 | Carrier 52PQ307 Wall/Window Air...
Fridg temp control not regulating the temp in fridg
Refrigerators like the Hotpoint Model HSS25GFP have a air damper that controls fresh food sections temperature. Your refrigerator also has a diagnostics feature and can at times locate the problem causing the fresh food section to cool too much. Either your auto damper has frost blocking it open or the=> WR55X10025 Thermister is defective.
Try using a hair drier to force warm air into the damper to see if the damper will close better by melting any ice that may have the damper stuck open.Here is the=> WR09X10050 Damper Thermister Assembly Instructions on how to change this part can also be found on the same page HERE If you have any questions please ask, Thanks Sea Breeze
WR09X10050 Damper Thermister Assembly Below
3_21_2013_11_05_01_pm.jpgThanks Sea Breeze
Mar 21, 2013 | Hotpoint HSS25GFP Side by Side...
Incorrect sea level
That just means the GPS' data is incorrect, you have to write to the company or something.
Jan 12, 2013 | Garmin Aera 795 Americas Aviation GPS -...
What if the code doesn't work for the refridgerator once we install the board? It justs beeps which means incorrect code.
Please pay careful attention to step 5
1. Press and HOLD down the alarm keypad
2. Press and hold the Freezer Temp DOWN Keypad ( - )
3. Release the Door Alarm Keypad and wait 3 Seconds
4. The control will display PE to initate the program mode
5. Entry is confirmed by pressung the Freezed temp Down Keypad (-) once more.
6. The control will display the CURRENT program code. This value should be validated with the Program CODE printed on the unit serial plate.
NOTE: If the program CODE is correct, The programming Mode is exited by closing the Refrigerator door(s).
7. Press the Refrigerator Temp UP Keypad (+) or the Refrigerator Down Keypad (-) to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temp UP keypad (+) to select the next digit
9. Once the desired program code is displayed, press and hold the Freezer DOWN (-) keypad until the progam CODE begins flashing indicating it has been saved.
Sea Breeze
Jun 08, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
My temp willnt work on the freezer
OK, I will get the service manual and be right back. Sea Breeze
Nov 10, 2009 | Samsung RS2556 Side by Side Refrigerator
HP increase at elevation using a Dyno Jet Dyno?
same dyno? same operator? theres something wrong. the lower altitude the better, as far as I know. But someone thats smarter than me and has high altitude /dyno experience would be better to answer the question.
Oct 01, 2009 | 1983 Mazda RX-7
Setting temp.is not correct working.
Look on the rear back panel of the freezer and see if there is a layer of frost building up. If yes you will need to unplug and remove the rear panel in freezer and defrost with a hair dryer. Once defrosted we need to inspect the defrost heater and defrost thermostat. I tried to find your model but I think maybe the number may be incorrect. The model number above your post will work but the one on your post will not. Anyway your refrigerator has a defrost problem and I will wait for the correct number so I can tell you better of what to look for. Let me know, Thanks Sea Breeze
Aug 19, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Not maintaining set temps but holds steady at 31 and 61
Could you double check your model number the number above your post is nothing like the refrigerator2.gif you are describing, Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 10, 2009 | GE PDS22LBN Bottom Freezer French Door...
Simrad CE44 GPS Receiver Logo
48 people viewed this question
Top Simrad GPS Experts
Are you a Simrad GPS Expert? Answer questions, earn points and help others
