Question about Tamiya America 1/24 Subaru Impreza Sti
Glue removal How to remove glue, Tamiya extra thin cement, from a plastic scale model, 1/35 Tiger tank mid production, to replace parts/sections?
Rasasiol
Posted on May 07, 2010
Looking for instruction manual for Tamiya 1/35 scale Cromwell tank kit 35221
Hi Mikey! I did ALOT of searching for about 2 days and I think I finally found them. There is a site here that has the Cromwell instructions
http://www.1999.co.jp/eng/image/10130033/10/0
You didn't specify if you needed the Mark IV or VI, but both are there.
Oct 29, 2014 | Crafts & Hobbies
The felt gasket came almost all the way off whats the best & easiest way to fix it
You will need to take the whole machine apart and decide whether you wish to reuse to old one or replace it. Remember, a new one will be VERY tight and hard to replace, ( on purpose ). If you old one is in good shape, you will need some super glue to glue it back on. I do not mean the product "super glue". It take a special cement, heatproof.
You may obtain a part number on "Sears Parts" by model number.
You may also find parts on "e-bay".
Be blessed.
Aug 20, 2011 | GE Dryer Repair Video Older Models
I have a 2005 Husky 137 saw that the bar oil tank leaks (drains out) when not using, can i fix it? or live with it.
It will be necessary to replace the entire plastic casting containing both tanks. Repair of plastic cracks is not practical due to inability of any form of cement/glue to bond with the plastic and saw vibration would hasten the process. Just empty the tank out when not using the saw. Good luck!
Nov 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
Glass panel unstuck
if product is beocenter 9000/8000/8500/9300/9500 remove screw under l/h side of panel, push panel to side and remove.careful to note position of plastic attachments and metal screw socket.lay face down on bench and apply thin ribbon of epoxy resin where double sided tape is,do not clean off old tape.apply glue over top.assemble plastic parts on top and leave to set.refit to machine and refit screw.
Oct 14, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Cracked screen
If the plastic cover is cracked but the LCD is fine, the fix is very different. In some ways it's actually harder than replacing the LCD, which is simply connected by a ribbon cable. One challenge for you is that, unlike the LCD, which is available as a replacement part (on Ebay - about $25), there is no direct replacement available for the plastic covering. You will need to pick up another 880 that is being sold for parts and then salvage the plastic screen from there. I'm not sure I can actually describe the replacement procedure to you without pictures but here is the general idea:
First, you need to open the remote so that you can work with the top half. To open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the ****-shell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Now, take the bottom of the remote that is holding the logic board and put it aside. You will only need to work on the top half of the ****-shell case. Ok, now looking at the face, there are 4 pieces of silver trim that are locking the plastic screen into the case, two on each side; the piece directly above the Mute button and the Prev button (they look like unmarked softkey buttons), and the two thin elongated pieces at the top on either side. To remove these pieces, you need to turn the top half of the casing over so that you are looking at the underneath at the area of these 4 trim pieces. If you look carefully, you can see that there are very tiny posts covered with glue that are holding in these pieces. You need to forcefully, but carefully scrape the glue off and try to push the trim pieces out from the back. Try to do this is carefully as possible, since the surrounding plastic is delicate. Once you pop these pieces off, turn the top half back right-side up. Now the only thing holding the screen down is a kind of rubber cement around the perimeter. To remove your cracked screen, you can pull it off from the bottom without worrying too much. However, be very careful when trying to get your replacement screen off of the salvage remote! The screen must be pried up gently and slowly from the bottom. If you use too much force, you risk cracking the screen as you pry it up. If you wind up scraping some of the black paint on the screen's perimeter, you can use a permenent marker to color it. Back on your good remote, remove as much of the cement as you can and lay down some double-stick tape (a glue stick may work also) and lay the new screen down so it is aligned perfectly in the space. Then attach the trim pieces and use some epoxy on the underside to affix them in place. Re-assemble your remote and it should be as good as new. Good Luck!
Sep 06, 2009 | Logitech Harmony 880 LCD Remote Control
Paying for part for LCD 4010 NEC MONITOR (MODEL: L404G6)
If you can't find the part, glue the crack with ABS pipe cement or liquid plastic model glue (use a toothpick to apply it to the crack from the inside of the part). If the crack is still displeasing to look at, hire a starving artist to make an inlay or custom trim piece to cover it up.
Apr 25, 2009 | Televison & Video
Cannot Remove Sticker Goo on Door of New Sharp R-420lw Microwave
Hi, Go get a can of wd40 and spray a rag with it then use wet rag to rub the old glue off-this will work for any kind of sticker or remains of stickers on most surfaces-wd40 works like magic when removing any old stickers-is especially awesome for Park pass type stickers on car windows!
Dec 20, 2007 | Microwave Ovens
Tamiya America 1/24 Subaru Impreza Sti Logo
435 people viewed this question
Top Tamiya America Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Tamiya America Toy Expert? Answer questions, earn points and help others
