Question about Video Cameras
Do digital camcorder heads ever need
Video and sound breaking up. Have used a head cleaning tape .
    Brigadier General:
  • 4,090 Answers
Time to move on! the heads are probably too worn to be servicable If you have used a cleaner without success its the end of life for the heads.
please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Samsung SC D363 camcorder displays green wide lines on playback function what is wrong?
Sounds like dirty video heads which is going to require a mini dv cleaning tape to clean the heads and the tape path. Worst case scenario if cleaning doesnt help is that it may need the video heads replaced. I hope this helps.
Sep 15, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
  1. Stop the tape.
  3. Play the tape.
  7. Play the tape.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
Timecode break after a camera cut. PD150 & PD170
dear,
this problem is related to the head drum of the camcorder as the head drum gets dirty ,this problem does occurs but using cleaning tape wouldnt help much, asu need to clean the drum assy manually.
Mar 24, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
Jan 28, 2009 | Sony Handycam DCR-TRV140E Digital...
Recordings are pixelized
Never use tape head cleaners, I suggest just use new blank tape and I recommend TDK minidv tapes, new tapes already serves as video head cleaner. If the problem is still there, manual cleaning is needed or it is possible that your video head is worn out already, you need profix then.
Dec 13, 2007 | JVC GR-DVF31U Digital Cybercam GRDVF31U...
Mini dv camcorder sony
the video head of your camera is dirty or need for replacement...but first clean the head using a blank new tape,don't use a cleaning cassette cause is too rough for the head just think using a sandpaper to the head what would happen it ruin the head...just forward the whole tape then play the recorded tape...5 times as it needed...if nothing change then it time replace the video head....
Aug 28, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sound Problem
Digital video camcorder are recording signals in very thin line (as thin as 1/8 of a hair.) Therefore, following symptoms may appear if video heads become dirty even a little. Video heads may become dirty under the following conditions: (1) When using the camcorder in humid or hot places. (2) When using cassette with damaged or dirty tape. (3) When using the camcorder in dusty places. (4) When using the video heads without cleaning them for a long time. Note: Before you make important recording, clean the video heads and make a test recording first. We also recommend cleaning the video heads after use before storing the camcorder.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Video Cameras Logo
49 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
