Question about Whirlpool Duet GHW9150P Front Load Washer
I stopped a load of washing and cannot get it to restart. HOW CAN I DRAIN the water in the washer, dump the water in the machiem and start over. I have removed the clothing from the washer. whirlpool duet unit.
  • 6 more comments
  • nylarebus May 07, 2010
    how do i know if the "control" is on? There is no light that gies on when I pucj "controlon" that I can see.
    nothing works yet.
    lights turn on for all operations. What is the "control on" button and how do I know it is on>
    i pushed the cancel/pause button as yOu suggested. NOTHHING! iSN'T THERE A KILL BUTTON OR COMBINATION SO THE UNIT JUST STARTS OVER?
    NO SOLUTION YET
    All of the lights work on all the functiions. as i move any dial, the light moves with me.
    drain the washer manually seems simple enuf, but it didn't work.
    i followed your suggestions. the lights stay on, but nothing happens.
    President:
  • 949 Answers
Try this first with the control on the same setting you were using.
Close the door and just push and hold start. It should try to finish the cycle,
If not:
Turn to rinse and spin and try starting there.
I am going to look up an alternative while you try this.
I will be right back
Posted on May 07, 2010
  • 6 more comments
  • Philip May 07, 2010
    If the first two tries do not work, try closing the door turning the control on and pushing the cancel button two times.
    Okay, sorry I did not understand that the unit is completely dead now. Do you get any lights or sound when you push any of the buttons?
    Great, thank you very much, the control on is the button on the left side. If the lights are on then the control is on. If you push the pause/cancel 2 times with the door closed what happens?
    I am sorry, let us walk through this one step at a time and we can solve it.
    When you pushed cancel drain 2 times with the door closed the lights did not go off?
    There is no master reset or kill switch unfortunatly
    Here are the steps
    1. Select PAUSE/CANCEL twice.
    2. The washer powers down (it may or may not drain)
    To drain the washer manually
    1. Select PAUSE/CANCEL.
    2. Select DRAIN/SPIN.
    3. Select HOLD TO START (for approximately 1 second) to begin the drain.
    4. When the spin is complete, the door unlocks.
    Were you able to walk through the steps?
    Since I cannot see your machine I am relying on you to tell me what it is doing.
    The lights are on, the door is closed and you push cancel drain 2 times. What happens? Any sounds, do the lights stay on, go off?
The machine is not draining water - it starts the washing cycle, takes in the powder and churns around but then stops when it needs to drain the water. If I empty all the water out, it will then spin the...
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 10, 2011 | Asko W6021 Front Load Washer
I have a series 90 washer and it just stopped and is full of water. It will not power up. where should I start?
must be overload trip. drain water first. reduce load. restart. if doesn't work, check CB or fuse inside the machine
Mar 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
WILL NOT STOP FILLING
Hello Friend, You either have a bad water level/pressure switch or your water inlet valve is bad. If you unplug the washer from the wall and the water stops filling the washer then it's not the water inlet valve. If it only continues to fill when wash cycle is started then you will need to replace the water level/pressure switch behind control panel. This should solve your problem. Happy to help, Tim.
Jun 30, 2009 | GE WHRE5260E Top Load Washer
1 month old electrolux FL IQ cuts off and won't restart
If it is only one month old then you should be covered by the warranty ??
To unlock the door place the drain hose in a bowl until the water comes out, if it wont then try blowing down the hose.
If you hear bubbles inside the machine then dump the hose back in the bowl
Once the water has all ran out switch the machine programmer to "off" and then try the door
May 31, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Whirlpool top loading washing mchine will not drain
If you can get any panel off of the dryer you will see a leather or rubber joint that connects to the pump. Sometimes the socks that go missing float over the top of the drum inside the washer and get caught in the pump. If the pump joint is not broken you should see it bound up or kinked. Depending on your washer you may be able to remove the drain tube and fish out the blockage.
May 27, 2009 | Frigidaire FWSB5700DS Top Load Washer
MACHINE RUNNIMG STOPPED SUDDENLY WITH THE LIGHTS BLINKING AND WE TRIED TO RESTART IT AGAIN AFTER DRAINING THE WATER THROUGH THE OUTLET PIPE &OPENED THE DOOR REMOVED THE CLOTHES AND RESTARTED IT AGAIN BUT...
turn on power switch,then press the spin speed button then push start, the water should drain then spin. if the water does not drain chech the drain pump button trap, located lower left front panel.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
