Question about Konica Minolta Di1610 Copier
Why cant i close the front cover for konica minolta di 1610
  • Konica Minolta Master
  • 1,297 Answers
Change the toner cartridge unit.
Posted on May 08, 2010
Code c-0400 on minolta dialta di 470
open the front door, upper left small access cover remove the cover and press trouble reset. if code comes back replace the scanner lamp and associated circuit board.
Try this site for a start for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 03, 2014 | Konica Minolta Office Equipment & Supplies
I have a photo copier machine minolta dialta di 470 that show error code c-0400
open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
C 1038
Open the front door, up left small access cover remove and push trouble reset button. Once reset the malfunction and turn OFF and ON the Power Switch. If the same malfunction is still detected, check cables for proper connection and, if they are okay, change PWB-B. If you can find one, quite old machine, a legacy Minolta, now Konica MInolta
Mar 04, 2013 | Genuine Konica Minolta Konica Minolta Di...
Konica minolta di 1610 replace drumkit
se mando fazer limpezas gerais sera que ele retirara o codigo (error)
Nov 12, 2012 | Konica Minolta DiALTA Di1610p Printer
Caro esperto codice errore c0510 minolta dialta di 1610 sapresti come fare per sbloccare
Amico C0510 - fusione fallita (temperatura di fusione del basso anormale) temperatura del termistore fusione roll undectable rimane al di sotto di 120 ° ... controllare il fusore
May 24, 2010 | Konica Minolta Office Equipment & Supplies
Konica bizhub di1610fp priter constantly gives a paper size error and requires paper reset.
Change the paper size,emter in the user modeor press the Utility key.I have the Minolta Di 1610 (copier/printer) and every function is OK.One toner cartridge is OK for 7500 copies,if you can the setting the user tools.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
How do I input ip address in Minolta DI1610
press the Utility/Counter -> Network Settings -> IP address
Feb 09, 2009 | Konica Minolta Di1610 Copier
Konica Minolta Di 520
Try resetting the copier first, power on - open the front door remove small cover on the right hand side press reset button - close door. The machine should now boot, but if the fault is still present a service call will be required.
May 09, 2008 | Minolta DiALTA Di520 Laser Printer
Konica Minolta Di1610 Copier Logo
71 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
