Question about Magic Chef MCWC30MCG Compact Wine Cooler
Unit stopped cooling and compressor is hot. - Magic Chef MCWC30MCG Compact Wine Cooler
    Guru:
  • 1,524 Answers
Try a "3-n-1" Start kit
Posted on May 07, 2010
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
Oct 15, 2017 | GE Refrigerators
Should my refigerator compressor be hot to the touch?
Hello friend, thanks for the post!
Based off the information you have provided your compressor can be hot to the touch because it is working to help cool down your refrigerator. I would allow it the opportunity to maintain proper temperature inside of your appliance before it stops running. I hope this is helpful. -Matt
Sep 23, 2014 | Frigidaire Refrigerators
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
Gold Whirlpool 25.3 cu.ft refrigerator stop working
if the compressor is very hot then it can be possible that the compressor is getting faulty,but also other possibility can be the compressor relay.if the relay beside the compressor is got faulty then the compressor gets over heated.so first unplug the unit from main power outlet and then remove the relay and check it with continuity to confirm the fault.is it relay or compressor.
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge and freezer do not get cold but unit has power
Check the freezer fan to ensure it is operating. If it is and there is at least air movement, maybe cool, but not cold, first thing to check is the condenser coil located either at the rear bottom or front bottom. Make sure it is clean. Dust/dirt can clog the condenser preventing the unit from rejecting the heat. Same as with your central a/c. If the condenser gets dirty/plugged, your a/c will stop cooling. Other possiblity is the compressor is not operating. You should be able to hear it operating, will sound like a low hum with slight vibration. In the event the compressor is not operating, unplug the refrigerator, gently place your hand on the compressor, (it will be found in the rear bottom) to determine if it is warm, hot, etc. If it is hot, leave the refrigerator unplugged for 10-12 hours to cool. There is a thermal overload within the compressor to shut it down in the event of overheating. While the refrigerator is unplugged to cool, make sure the condenser is clean. Most causes of compressor overheating are related to a plugged/dirty condenser. Let me know if this helps.
Richard
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
MCWC30MCG stopped cooling
Handy hubby,
welcome to Fixya,
It sounds like the compressor!
Not worth replacing this very expensive part.
Was it so hot you could not keep your hand on the compressor?
If yes then it's most likely your compressor.
Happy to be of assistance.
Sorry about your lose
Huuum
Please remember to leave a rating
Oct 07, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Magic Chef MCWC30MCG Compact Wine Cooler Logo
257 people viewed this question
Top Magic Chef Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
