Wife just told me this
Whirlpool Stylemaster Top Loader
Wife just told me this is a progressively worse problem....she had to run more than one spin cycle to dry clothes......started the washer the other night, and it got stuck in the spin cycle......wouldn't move or drain.....I've played with the knob, and it did try to move but to no avail.....I also noticed the drain hose jerking in the process.....I checked the coupler I replaced about a year ago, and it looked great!
  • 1 more comment
  • Hezekiah12 Mar 27, 2008
    Also a note, it will not agitate in the wash cycle even........at one point in the spin cycle it made about an 1/8th of a revolution and then just started humming again.......
    I'm thinking drain hose, drain pump, or dog ears on top of agitator.....can anyone narrow it down? thanks........
  • Hezekiah12 Mar 30, 2008
    wilbur,
    I just didn't believe you sir. It's a Whirlpool LBR6233AW0 Top Loader. I couldn't even find dog ears or an agitator drive cam in this model after my wife brought the dog ears home. I finally decided to pull the drain pump off and found one of my 9 month old sons sock stuck in there.......FixYa!
  • Hezekiah12 Mar 31, 2008
    I guess I hadn't really thought about it too much sir. I figured it was so small it just kinda got sucked through.....?????
  • 185 Answers
Try a new drain pump make sure there is no foriegn objects in there
Posted on Mar 27, 2008
  • Anonymous Mar 28, 2008
    check timer
  • Anonymous Mar 30, 2008
    are you wondering how the sock got in there?
SOURCE:
How do I take the whirlpool washer cabnet off?
Earlier whirlpool tubs had 4 screws under rubber plugs that unfortunately rusted if you manage to get them out then the complete top lifts of the base section
later models just prise apart as they have eliminated the screws
there are manuals on line to download
Apr 09, 2015 | Whirlpool Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
After the first cycle the washer hangs up on the first spin cycle. During this time it makes a hum but does not progress forward. You can move the control dial to the last spin cycle and it will...
Please check iff the motor speed is good enough. If slow check on the capacitor and replace the capacitor.
If this wont improve then the controller unit is a possible suspect.
Make a diagonistic check on these two sections and the possible answer migh help.
Aug 24, 2010 | Roper RAS8445KQ Top Load Washer
Whirlpool not spinning fast enough. Not
We had same problem which got worse. I had to take the tub out as it wasn't engaging on spin. I feel a washer
was left out at factory as it wouldn't tighten down.
After a few attempts I finally found a washer that was
right ( elec dept ). You basically take the whole thing apart.
It works now but we bought extra washers
Feb 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Washer motor runs, but the drum does not spin on the spin cycle
It is most probably the motor coupling if you have a Whirlpool top loader.
Ash
Oct 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washing machine agitator problem
Simply buy the "doggies" and install it them
Sep 22, 2009 | Whirlpool Washing Machines
Amanna wasing machine 3.2 cu. ft. top loader
i would try removing the lower acess panel(2 5/16 screws . from there you should be able to see where the "ticjing" noise is coming from, likely source is cracks in belt assy
Oct 07, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
