Once I plug the dvd player to the tv, I get the video to show, but no sound.
  • 28 Answers
Some DVD player have dedicated left-right line output aside from the set of 6 outputs for 5.1sorround. If yours got the same connect the the left-right outputs to the line-in jack of your TV and select it from DVDs menu/sound options.
Posted on Mar 27, 2008
2 Suggested Answers
mlapres
  • 757 Answers
SOURCE: No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
Posted on May 08, 2009
How do I get the dvd player to work. I have it plugged in, but the one cable do I need it, even if they don't have surround sound? The coaxial digital cable. Do I need that to get it to work?
Make sure you have the audio plugs in the same input as the video. On the back of the dvd you will have a video and audio out. On the TV you will have to put these matching cables on the input of the tv. Once you have that you need to make sure the tv source is on the same input you have plugged into for this to work. If you have an HDMI input on your tv and an HDMI output on your DVD then you can use that instead of the three cables .
Dec 24, 2014 | Sony BDP-S1200 High Definition blu-ray DVD...
Video Does not work on New Magnavox TV
Hi, it sounds like your problem is that you've selected the wrong "video input" for your DVD player. Your new television most likely has at least 3-4 (sometimes 6-7) different inputs for video. With your DVD player connected and turned on, press the "Source" button on your TV to cycle through the different inputs. Be sure to wait 2-4 seconds between selections to give your TV enough time to switch inputs. If your DVD player has "color coded" output cables, it's most likely a "component" video connection. See if one of your video inputs on the TV is called "Component". Some other video types are Video, DTV, HDMI, SVideo, Component, Composite, RGB, PC Input, etc...
Jul 24, 2013 | Sylvania SDVD7014BJ 7 in. Portable DVD...
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
May 07, 2009 | Yamaha HTR-6130 Receiver
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
My portable COby DVD player stopped working. DVD rotates when I put it in by screen remains black... With TV out option sound comes out and picture/sound shows on TV once I connect it to DVD
I have had some very bad luck with Coby products and am sorry to hear that you have too but please make sure that the connector jack is clean and functioning properly. The connection jack has a device inside it that knows when the plug is inserted and then sends the audio and video out to the TV. If the connector is really dirty it could be that the connector is not working properly.
There isn't a lot more to look at unless there is some obvious problem with the screen such as a loose wire or a broken hinge.
Feb 26, 2009 | Coby TF-DVD8107 Portable DVD Player with...
I cannot see the video when i plug the DVD Player to my TV set. The model is AKAI ADVC-7013
start with the sound , do you have some speakers or amp that can take rca connnectors if so plug in to audio out and if you hear sound then the video is presumed ok too , likely some setting or cable issue then.
if no sound the the proc amp is shot.
Apr 26, 2008 | Akai DVDP5851 DVD Player
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
No video, only sound from tv tuner.
You need to plug the male yellow wire into one of the female wires that says media control...... something along those lines..... youll figure it out
Oct 06, 2006 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
27 people viewed this question
 Grubhead
Grubhead
