Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
My Bosch dishwasher is only 2 yrs old and for the following two nights does not want to pump out the water. If I drain it, it sometimes starts the cycle and sometimes not?
  • Bosch Master
  • 3,247 Answers
If no warning lights show up, then it is a matter of finding if the outlet is blocked somewhere. I am assuming the fact you can drain it manually means the pump is ok. Perhaps some sensor which is covered in muck.
I would start by cleaning the filters at the base and then running the unit with a dishwasher cleaning kit (without dishes in it). Finish cleaning kit is quite good and the instructions are on the pack.
By the way these units normally have a 2 to 3 year warranty on some parts. I am assuming you have the proof of purchase so that you can call the Bosch support guys.
Posted on May 07, 2010
Hi i have a Bosch electronic management dishwasher its about 5 yrs old. it washes but the water does not drain out. can you help
It is either the waste water pump has stopped working, whichis accessible from below the dishwasher (lay dishwasher on back and remove 2screws from bottom plate) or alternately the float (open dishwasher door, removebottom basket and lift dome shaped float up and down a few times).
Jan 13, 2011 | Bosch 24 in. SHY56A05 Stainless Steel...
My Bosch dishwasher is not draining water and thus leaking on the floor. It is 7 yrs old but only has been used for 3 yrs as I was away. It was run weekly in my absence. Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 07, 2010 | Dishwashers
Bosch dishwasher Water pump not stopping
Hi.
You need to replace the pressure switch located near to the pump, in the drain assembly.
The main function of the pressure switch is to turn off pump when there is no more water.
The pressure switch can be tested reading ohms on switch contacts and jumping the switch. This must be done by a technician.
You can get parts and a quote on repair calling Bosch at the number listed on the manual.
Regards.
Nov 20, 2009 | Bosch Dishwashers
I own a Bosch SHU3036UC not draining properly
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Aug 04, 2009 | Bosch 23 in. SHU303 Built-in Dishwasher
My G E Power1 Dishwasher is holding in alot of water,I know a little is normal.There is a lot and the water it feels slimmy.Just 2 yrs old well takeen care of.HELP
Check the following areas for faults. This is an apparent drainage issue.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
Jun 24, 2009 | GE Dishwashers
Does nt drain
Check the following to address this issue further.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or Control board
Jun 19, 2009 | Bosch Dishwashers
Dishwasher not draining potential blockage with Bosch classixx
check the following areas to combat this issue.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer/control
Jun 18, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch smu2046uc doesn't drain completely (water sits in the very bottom of the drain) and mildew builds up inside the dishwasher quickly--makes dishes dirty. How do I solve?
check the following parts for their operational value. replace any failed part.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 15, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
278 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
