Question about Kenwood Car Audio & Video
Need a wiring diagram for a kenwwod dash mounted
    President:
  • 676 Answers
This is a basic wiring for kenwood. If you have more wires just let me know and I would be glad to help. please rate
Posted on May 07, 2010
2007 Mustang dome wiring diagram
Does the door currently have 'Courtesy Lamps' ?? If not,wires would have to be ran from under dash thru the door jamb harness bellows....Technical,tricky stuff....Best leave this one to the pros !l
Aug 30, 2014 | Ford Mustang Cars & Trucks
How to replace relay flashers on 1996 cadillac
On Cadillac Deville, the Flasher is located:
- Hazard flasher: Front seating area, driver side, under dash, mounted on passenger side of steering column
- Turn signal: Front seating area, driver side, under dash, mounted on passenger side of steering column
  1. Remove the necessary sound insulator panel(s) from under the instrument panel.
  2. Remove the flasher from the retaining clip and disconnect the wiring connector.
To install:
  1. Connect the wiring connector to the new flasher and install the flasher in the retaining clip.
  2. Install the sound insulator panel(s).
If you need additional details, diagrams or some copy about Owners Manual, click it to contact us.
Hope this helps, dont fogetted to rating this answer and leave us a testimonial comment.
Oct 13, 2011 | 1996 Cadillac DeVille
I have c-class 200K 2001, classic, i would to change radio to new one to have DVD/MP3/GPS and bluetooth ....what i have to do
its not to hard if you have basic skills or better you must remove the old stereo from car which can mean certain parts of the dash will have to come out usually the surround around the stereo you may also need a special tool to get the old stereo out of the dash then you will have to find a wire diagram off the factory stereo so you can wire the factory speakers up to your head unit also you will need to mount the new stereo to the dash which is simple a mount frame should be in the new head unit box
Oct 05, 2010 | 2001 Mercedes-Benz C-Class
Need 72 Nova wiring dash diagram
Go to faxonautoliterature. They can provide you with a wiring diagram direct from a GM service manual for your car for $8. I've used them before and had excellent service. Hope this helps.
Apr 28, 2010 | Chevrolet Nova Cars & Trucks
I need wiring diagram for Kenwood kdc-mp228 radio
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/
Just input your model number in the third search field, download the user manual, then look on page 25 for wiring connections. Hope this helps.
Aug 23, 2009 | Kenwood KDC-MP228 CD Player
I need to find out the weiring diagrame to install it
Equalizers Like a crossover, the equalizer gets installed between your receiver and your amplifier. The outputs will be preamp connections to your amplifier. You'll find EQs that are designed to be installed in the dash, above or below your receiver. Others are designed to be mounted in a remote location, like the trunk. Either way, the wiring connections required will be the same. To install:
1. Mounting the equalizer:
A remote-mount EQ can be securely mounted with just a few screws. Anywhere between the receiver and the amp is fine. Most people mount the EQ in the trunk near their amp, especially if you have more than one amp. This also makes it easier to add additional amps later. You should mount it where it will be easy to get to so that you can make adjustments without too much trouble. Don't mount your EQ directly on steel — you will invite noise problems. Instead, install it on a non-conductive board and attach the board to the car body (or use rubber grommets under the screws to isolate the crossover).
An in-dash EQ can be mounted above or below your in-dash receiver, assuming that you have space available in the dash. This will require custom installation work. Another option is installation below your dash, in a universal under-dash mounting kit. To install the under-dash mounting kit, attach it to the mounting surface using the supplied self-tapping screws. In most cases, the use of an under-dash kit will require modifications to the kit or to the mounting surface.
3a-xover.jpg Locate the remote turn-on lead behind your radio (usually a blue wire). 3b-xover.jpg Connect the turn-on lead from your amplifier wiring kit to the blue wire. You can wrap the bare wire ends together and cover with electrical tape, or use solder. 2. Making the power connections:Your EQ will require 12-volt power, ground, and turn-on signal connections.
  • To obtain 12-volt power: Cut a length of small-gauge cable (16 gauge is typically sufficient) long enough to reach from the EQ location to your vehicle's fuse panel. Strip one end of the wire, and attach it to the EQ's power input. This may require a crimp-on connector, or bare wire might be sufficient, depending on the equipment you're installing. Route the wire from the EQ location to your car's fuse panel. Using a fuse tap, connect the wire to a source of switched 12V power.
  • To ground the EQ: Remove a bolt near the EQ mounting location. Crimp a ring terminal to one end of a length of small-gauge wire, and then bolt the terminal tightly to the vehicle's metal chassis. Scrape away any paint and clean the bolt location thoroughly. If you can't find a convenient ground screw or bolt, drill a hole for one — be careful not to drill into the gas tank or a gas or brake line.
  • Making the turn-on connection: In most cases, you can tap into your in-dash receiver's amp turn-on lead to get a turn-on signal for your EQ. Remove the receiver from the dash to access the turn-on wire (usually a blue wire). For step-by-step instructions on removing your vehicle's radio, see your vehicle-specific Crutchfield MasterSheet™, or read our In-Dash Receiver Installation Guide. Strip the insulation off a small section of this wire coming from the radio. Strip the insulation off another small-gauge cable that's long enough to reach from the in-dash receiver to the EQ, then connect the two with crimp caps or solder. Wrap the solder or crimp connection with electrical tape to guard against a short. Using wire ties to secure the wire, route the turn-on lead behind your dash all the way to the EQ mounting location.
3. Making the signal connections:
In most cases, you'll be routing RCA cables from your in-dash receiver's preamp outputs to the inputs of your EQ. While your receiver is out of the dash to access the turn on lead, connect a set of RCA patch cables (long enough to reach your crossover in its mounting location) to these outputs, taping them together so they won't come apart. Route the patch cables (again using wire ties) behind the dash, and to the crossover mounting location.
May 14, 2009 | Alpine Car Audio & Video
Heater blower motor wiring diagram
replace the bolwer motor relay mounted on the fire wall the relay is stuck in the on poition.
Dec 07, 2008 | 1996 Oldsmobile Aurora
Kenwwod Cd Player
there is a wire on the harness (pink or brown i think) called cell phone mute. if this wire is touching power or ground or any other wires you will have these problems. make sure this wire is taped off and secured behind the dash.
If it was hooked up intentionaly it will mute your stereo anytime a call comes in on a cell phone.
Aug 04, 2008 | Kenwood KDC-MP528 CD Player
Wiring diagram
First, goto a store and buy a snap in wire harness and a mounting kit. There are wire diagrams in the packaging. Wire your wire harness into the radios wire harness (everything is color coded). Follow the intructions to install the mounting kit. It should tell you what screws to remove from your dash and so forth. Just remeber were everything goes. Next, after you remove the old radio, snap in you wire harness to the cars wire harness. Then, test the radio to see if it powers up and all speakers are working. Lastly, put you radio in your dash, and put everything back togeather. The number one rule in installation is take your time. If you rush, you will brake something.
Jun 02, 2008 | Pioneer DEH-P2000 CD Player
Car Audio & Video Logo
210 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
