Question about Kenwood Audio Players & Recorders
KW TS-850S Display Failure - Kenwood Audio Players & Recorders
Why does my Kenwood TS 790 E when pressing call button causes C2 fault on display?
http://www.iw2nmx.it/Kenwood%20-%20Trio/TS-790%20Instruction%20and%20Service%20Manuals%20plus%20mods/TS-790%20Instruction%20Manual.pdf
Jul 14, 2014 | Kenwood Radio Communications
ATU failure
I would recommend you check on
mods dk Modifications for radioamateur
There is a lot of good information there, and people are very helpful.
Feb 05, 2014 | Kenwood TS-2000
Displaying the clock on the Jvc kw hdr720
Hey did u find a solution? Please let me know, the manual just shows how to set the clock but not.display it, I believe it can be but just haven't found how to do it
Aug 02, 2012 | JVC Kwhdr720 Kw-hdr720 Double Din...
Passat 2001 with codes P0012,P0340 it runs fine the turbo kicks in no problem I originally found some broken vaccum line and replaced them but the codes still return
P0340 - Camshaft Position Sensor Trouble
Your cam timing timing is off and the sensor is fine. They are very simple sensors...it's just a magnet...and magnets don't go bad. Check the timing. Incorrect allocation means that the camshaft isnt where the computor thinks it should be at any given time. This could be casued by the base engine timing being off by a tooth or by a problem in the camshaft adjuster.
P0012 Camshaft A: Advance Setpoint not Reached
The code P0012 can be set by the following concerns: Faulty cam adjuster, Faulty cam adjuster solenoid, Low oil pressure, Sludged oil passages and Sticky camshaft.
The variable cam timing uses engine oil pressure diverted to the adjuster mechanism by a solenoid duty cycled by the PCM. Low oil pressure or severe oil sludging can affect camshaft timing operation. Always check oil level and condition when camshaft adjustment codes are present.
Using a full function Volkswagen compatible scan tool enter address word 01 (Engine). Function 08 (Read Measuring Value Blocks) and Display Group 091 (Power Enhancement Camshaft Adjustment).
Observe the 4th display field "Active Camshaft Adjustment Angle" With the engine at idle. The 4th display field should read between -3.0 to +6.0 degrees KW if the camshaft is in the normal unadvanced position. Any other reading at idle indicates that the camshaft is shifted from the normal unadvanced position
Accelerate the vehicle from a standstill in 1st gear using wide-open throttle and observe the display in field 4 again. Under heavy acceleration the display should read between +16.0 to +25.0 degrees KW. This indicates that the camshaft has shifted to the full advance position.
If the display in field 4 does not change from the values in test step 2 or if the display changes but does not reach a minimum of +16.0 degrees KW (i.e. between +6.0 and +16.0 degrees KW), the camshaft timing adjuster mechanism is not advancing the camshaft.
Failure to advance the camshaft could be caused by a faulty cam adjuster, a faulty cam adjuster solenoid, low oil pressure, sludged oil passages, or a sticky camshaft.
Hope this helps (remember to rating this free answer and leave ue some testimonial comment)
Oct 11, 2011 | 2001 Volkswagen Passat
How to set clock jvc kw-xc770 car stero
1 Press SEL for more than 2 seconds. One of the PSM items appears on the display. 2 If "PSM CLOCK H" does not appear, press fast forward and up or fast backward and down repeatedly until it appears. 3 Turn the control dial to adjust the hour. 4 Press fast forward and up or fast backward and down until "PSM CLOCK M" appears on the display. 5 Turn the control dial to adjust the minute. 6 Press SEL again to finish the setting.
http://www.jvc.ca/manuals/KW-XC770.pdf
May 05, 2011 | JVC KW-XC770 CD / Cassette Player
Toshiba E_Studio 850s very slow to print or copy
U can try format the hdd ( 08-690 ).
*E-fillings files will be missing
Or, perform bad sector checking on the hdd ( 08-694 )
*Take some times to finish the test
Jul 16, 2009 | Office Equipment & Supplies
Urgently need aspare part for my Kenwood TS850 s/At HF Tranceiver
Watch ebay or QRZ.com for a used/non working unit that has a good display or maybe someone may part out a 850 on ebay.
Dec 30, 2017 | Kenwood Radio Communications
Touch screen half loading only
Try uninstalling the TS from the control panel-system-devices (hardware).
Reboot and reinstall the drivers when asked.
The driver must match the OS.
The TS may be defective, does it operate proper on another Pc?
Mar 14, 2008 | Computers & Internet
102 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
