Question about Air Tools & Compressors
I need an owners manual for a Mastergrip paint sprayer. It is a 10-pc set and I got it without any instructions. Does anyone know how I can get an instruction manual or owners manual?
I have a Mastergrip HVLP Paint gun set up with the manual. If you would like me to copy it for you, I will. I can also answer questions for you. Ken
Posted on Sep 17, 2010
Where can I find a schematic for the Krause & Becker paint sprayer? Mine is no longer working, and I noticed a disconnected set of wires hanging out the bottom of the pump casing.
[PDF]Airless Paint Sprayer - Harbor Freight Tools
manuals.harborfreight.com/manuals/68000-68999/68001.pdf
Airless Paint Sprayer. Item 68001. Read this material before using this product. Failure to do so can result in serious injury. SAve thIS mAnuAl. Notice.
Sep 26, 2015 | Tools & Hardware - Others
Instructions for earlex 120 sprayer
http://www.manualslib.com/manual/388222/Earlex-Ags120.html
there is your link for your spray gun in general every time you use any spray gun it needs to be cleaned run solvent through it to clean it -water for latex, paint thinner for oils remove the tip housing take out the fluid needle clean it every time so it looks like new.
As for thinning stay around 15% in general latex paint does not atomize well so I tend to stay away from latex on metal parts or like a small box and so on however yes we use latex on homes but an airless sprayer is used you basically have a style of "cupgun" thats for detail work... EARLEX AGS120 Operating Instructions Manual
Oct 19, 2014 | Tools & Hardware - Others
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Mastergrip hvlp paint sprayer
Probably have a blockage in your airbrush. Disassemble the air brush and clean thoroughly. Be sure to disassemble and clean after every use session. Be sure to mix the paint. If the paint has settled, it may be too thick to spray.
Oct 20, 2013 | Air Tools & Compressors
Graco ultimate max11 490 paint sprayer does anyone know how it works because i have no instructions
Here you can find manuals for your Graco sprayer: http://www.graco.com/Internet/SiteSearch.nsf/Search?OpenAgent&Mode=M&Query=Ultra%20and%20Max%20and%20II%20and%20490
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Apr 04, 2011 | Air Tools & Compressors
I have a Wagner 834cw15. Spraying fine 10 mins ago. Now...can't get it to prime. Any suggestions? Spraying oil based kilz
http://www.wagnerspraytech.com/portal/loader.php
I cannot find model 834
Check your owner's manual for troubleshooting steps
We used paint sprayers every day for years.
The prime valve goes bad
The steel balls that direct the paint between prime and hose, wear out
The steel ball that holds prime and hose pressure wears out
The steel balls can also get stuck
Turn prime lever on
Take a hammer and tap/bang front of paint sprayer until ball comes loose
I cannot see your sprayer so I don't know where the ball is located
The photo below says, keep lever up >> in your case lever is down or in prime position while tapping
To post a photo of your paint sprayer so I can see it:
Read:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answersAnd then add comment at page bottom and it sends me an e-mail
I will be here for another 45 minutes. Its 526 cst
Oct 26, 2010 | Air Tools & Compressors
MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
May 22, 2010 | Campbell Hausfeld Air Comp Basic Spray Gun...
Kirby paint sprayer attachment
HERE is the manual, just instead of shampoo use water-based paint and do nut put that nozzle on the sprayer. WASH IT WELL after you use it. Honestly - you better off buying a spray can. Painting with Kirby - MESSY. May sound strange from someone who makes living selling Kirby stuff but I just hate salespeople making it sound as if Kirby vacuum is ONLY appliance that you ever need to buy...
Rocky
Apr 25, 2009 | Kirby G5 Bagged Upright Vacuum
Air Tools & Compressors Logo
598 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
