Question about Brother MFC-8440 All-In-One Laser Printer
BROTHER MFC-8440, shows Paper Jam, however all the paper has been removed. We have shut & restarted the printer, restarted the computer. Cleaned the printer, readjusted the paper tray etc. It continues to show: PAPER JAM and there is absolutely no paper jammed.
    Guru:
  • 163 Answers
Nothing to do, just shut off the printer and wait for 5 min. Then remove the tray and adjust the tray according to paper size and then try to print.
Posted on May 07, 2010
  • bandrews98 Mar 22, 2011
    I did just that, then tried to print but to no avail!
  • Willam T Sep 01, 2014
    I did the same way repeatedly more than 10x but message paper jam still prompt. I even shut off power for 30 minutes and repeat the above steps.
How can I remove a paper jam from under the fuser bar in Brother MFC-8440?
sometimes a good long pair of tweezers helps , I use fishing forceps myself . have 4 different sizes from 2 inch to 14 inch
Oct 27, 2015 | Brother MFC-8440 All-In-One Laser Printer
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
The printer says there is a paper jam. I have
Try adjusting your paper tray. If you have the tray that adjusts from legal to letter it sometimes gets wiggled to some place inbetween. Just push it back into the letter position.
Apr 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Paper jam How do I correct this? There is no paper along any pathway!!
does it ever reset by opening and closing front door? if not, there could be paper stuck in fusing area behind rear door. open and inspect. if you see no paper, pull drum unit out and locate open slot in the bottom, center of drum unit. could be a small scrap of paper in that slot.
hth,
razors
Jan 28, 2009 | Brother MFC-8440 All-In-One Laser Printer
Paper Jam
sometimes the paper gets jam internally if the small piece of paper is just not letting the gears to move fluently this problem cad occur.for resolving this the whole printer needs to be opened and cleaned part by part.
but sometimes unplugging the printer from the main power outlet for sometime the replugging it again resolves the problem.
Dec 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
Hello, I have Brother printer MFC 8440.I keep getting mesaage that i have paper jam. I checked all places and there is no paper jam.How can I fix that problem?
It's possible there is still a very small scrap of paper left. If you have a can of air blow it in and try to dislodge it. If that doesn't work try to unplug it wait a minute and plug back it.
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Error message "paper jam"
u need to remove the fuser and remove the paper in it, put fuser back in the reverse
Jun 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Paper jam on my brother mfc 8440
It is possible that a small piece of paper is stuck in the paper path above the primary feed roller. It will most likely need to be disassembled.
Jan 16, 2008 | Brother MFC-8840D All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
1,095 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
