Question about Lexmark X73 All-In-One InkJet Printer
Cannot find disc to install - Lexmark X73 All-In-One InkJet Printer
  • kumar007
    kumar007 May 11, 2010
    you have not mentioned about printer's model, how can anyone help you? if you give us your printer model name and number, we might solve your driver problem. don't worry it is easy and posible.
  • Official Brand Answer
  • 3,344 Answers
There are Lexmark X73 drivers available for download in the Lexmark website. Just go to this link: http://bit.ly/97cvMv. Click on the Microsoft or Macintosh dropdown to choose the version of the operating system of your computer. If you don't see the operating system of your computer in the dropdowns, that would mean there's no driver available for it. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Posted on May 07, 2010
    Brigadier General:
  • 4,090 Answers
Go to the lexmark website SUPPORT and type in the model and number Acess to drivers and software is free
please rate my help++++Thanks for using FIXYA
Can i change the discs and pads on a 2003 jag s type 4.2 myself. I have been informed that only jag can do it because the pistons need resetting in the calipers, coz its an electronic brake system?? Is...
it's nearly identical to the lincoln LS, same platform
SECTION 206-00: Brake System 2003 Lincoln LS Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/17/2004
Front Disc Brake adobe.gif Printable View (243 KB)
Material Item Specification High Temperature Nickel Anti-Seize Lubricant
F6AZ-9L494-AA ESE-M12A4-A Brake Parts Cleaner
F6AZ-2C410-AB -
  1. Remove the parts in the order indicated in the following illustration and table.
    Item Part Number Description 1 - Bolts (Part of 2N386) 2 2N386 Guide pin/boot 3 2B120 Brake caliper assembly
    Removal Note
    Installation Note 4 2001 Brake pads
    Removal Note 5 2L200 Slippers 6 N808237-S101 Bolts 7 2B292 Brake caliper support bracket 8 1125 Brake disc
    Removal Note
    Installation Note 9 W701950-S100 Rivets 10 2C208 Brake disc shield
    Removal Note
  1. To install, reverse the removal procedure.
Item 3: Brake Caliper Assembly Removal Note
  1. Remove the caliper flow bolt and the 2 copper washers. Discard the copper washers.
Item 4: Brake Pads Removal Note
  1. Compress the disc brake pistons.
    • Use a wood block or used brake pad to protect pistons and boots.
Item 8: Brake Disc Removal Note
  1. If the brake disc will be reused, match-mark the hub and brake disc.
  1. ani_caut.gif CAUTION: If it is necessary to machine the brake disc, only use a hub-mount brake lathe.
    Measure the brake disc and resurface as necessary. Install a new brake disc if beyond specification.
Item 10: Brake Disc Shield Removal Note
  1. ani_caut.gif CAUTION: Use a 5.5 mm (0.22 in) drill. Do not exceed past a 6.0 mm (0.24 in) drill.
    Drill out the rivets.
Item 8: Brake Disc Installation Note
  1. Clean any rust or foreign material from the brake disc and wheel hub.
    • Use a suitable brake parts cleaner to clean the brake disc and hub surfaces.
    • Apply a suitable anti-seize lubricant to the hub flange.
Item 3: Brake Caliper Installation Note
  1. Install new copper washers.
Aug 04, 2011 | 2003 Jaguar S-Type
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
Why are there two installation discs included with the product, and on which computer do I install which disc? Disc 1 is called "Install Disc", and Disc 2 is called Restore Disc.
Disk 1 instals the software and disk 2 is used when something goes wrong but is not used until then.
You only need to install disk 1.Thank You for choosing FixYa.com.
May 18, 2011 | Global Marketing Partners Windows 7...
I just installed The Print Shop install/program disc with no problems, now I can't install the image disc, or do I have to insert the disc every time i use the program?
you can i have install it everytime or just copy the disc to your computer make a folder in your my pictures folder on the pc and call the folder print shop images. Then just copy all the files from the disc to there
Apr 10, 2011 | Computers & Internet
Installing sims complete collection to laptop without disc 1, but got disc 2,3 and 4.
HI, you cannot install the game with incomplete discs. It is required. Try searching and downloading files of disc 1.Ex. Sims disc 1 download.In the installation it will prompt you to insert the next disc, then you can use your discs
Feb 25, 2011 | EA - Electronic Arts Sims: Complete...
How to take back rotors off a 1994 honda civic.
PATH: Brakes > Front Disc Brakes > Brake Disc (Rotor) > Removal & Installation Removal & Installation
  1. Raise and support the front of the vehicle on jackstands. Remove the front wheels.
  2. Remove the caliper assembly; do not let the caliper assembly hang by the brake hose, instead support it with a piece of wire looped around the front spring or control arm.
  3. Remove the retaining screw from the brake rotor and remove the rotor from the hub.
An impact driver, No. 3 phillips screwdriver bit, and a hammer may be needed to remove the retaining screw. It is fairly easy to destroy the screw slots using an ordinary phillips screwdriver to remove the tightly driven screw (see photo).
  1. To install the disc, replace the disc on the hub, screw in the retaining screw and replace the caliper assembly.
PATH: Brakes > Rear Disc Brakes > Brake Disc (Rotor) > Removal & Installation Removal & Installation
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Disconnect the caliper from the caliper bracket. Support the caliper out of the way with a length of wire. Do not allow the caliper to hang from the brake hose.
  4. Remove the caliper bracket.
  5. Remove the two 6mm screws and the brake disc. If the brake disc is difficult to remove, install two 8mm bolts into the threaded holes and tighten them evenly to prevent cocking the rotor.
  6. Install the rotor in position. Install the two 6mm retaining screws.
  7. Install the brake caliper. Install the tire and wheel assembly.
Sep 15, 2010 | 1994 Honda Civic
How do remove rear rotors on 2004 ford sport trac
Caliper removal
  1. Disconnect the brake hose.
  2. Remove the bolt.
  3. Disconnect the rear wheel brake hose (2A442).
  4. Remove the copper washers and plug the brake hose.
  1. s2r~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not remove the guide pins or guide pin boots unless a problem is suspected. The guide pins are meant to be sealed for life and are not repairable. Use Silicone Brake Caliper Grease and Dielectric Compound D7AZ-19A331-A (Motorcraft WA-10) or an equivalent silicone compound meeting Ford specification ESE-M1C171-A for re-lubing the caliper slide pins. Other greases can swell the guide pin boots, resulting in contamination and accelerated corrosion or wear of the caliper slide pin mechanism.
    Remove the rear disc brake caliper (2552).
    1. Remove the brake caliper bolts (2W303).
    1. Lift the rear disc brake caliper off the rear disc brake caliper anchor plate (2C220).
  1. Inspect the rear disc brake caliper for leaks.
    • If leaks are found, disassembly is required. Refer to Caliper in this section.
Disc Removal and Installation
  1. NOTE: When removing the rear brake disc (2C026) in this procedure it is not necessary to disconnect the hydraulic lines.
    Remove the rear disc brake caliper (2552). For additional information, refer to Caliper in this section.
  1. NOTE: If the rear brake disc binds on the rear parking brake shoe and linings, remove the adjustment hole access plug and retract the parking brake shoe and lining.
    Remove the rear brake disc.
  1. s2r~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use a hub-mount brake lathe if necessary to machine the rear brake disc. For additional information on machining brake discs, refer to Section 206-00 .
    Measure the rear brake disc, and resurface as necessary. Install a new rear brake disc if beyond specification.
Installation
  1. s2r~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To prevent interference with rear disc brake caliper operation, install only the correct caliper bolt.
    NOTE: Make sure the stainless steel shoe slippers are correctly positioned. Install new slippers if worn or damaged.
    NOTE: When installed, the locator notch on the brake pads will be located at the upper end of the rear disc brake caliper.
    Install the rear disc brake caliper.
  1. Install the rear wheel brake hose.
    • Connect the brake hose and install the caliper flow bolt.
      • Use new copper washers.
  1. Bleed the disc brake caliper. For additional information, refer to Section 206-00 .
  1. Install the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Verify correct brake operation.
Dec 17, 2009 | 2004 Ford Explorer Sport Trac
2001 brake pad replacement 2001 nissan quest
The hard part is pressing the caliper piston abck into the caliper so you can get the new, thicker pads over the rotor. A large C Clamp works best.
SECTION 206-03: Front Disc Brake 2001 Villager Workshop Manual
REMOVAL AND INSTALLATION Pads —Front Disc Brake Removal
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the front disc brake caliper bolts. torx bit. T20?
  1. Support the front disc brake caliper from the front strut and spring assembly using mechanics wire.
  1. Remove the front disc brake pads.
    1. Remove the outboard front disc brake pad.
    1. Remove the inboard front disc brake pad.
Installation
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure the master cylinder reservoir does not overfill and spill brake fluid while retracting the front disc brake caliper piston.
    NOTE: It is necessary to fully retract the front disc brake caliper piston in the bore before installing the front disc brake pads.
    Install the front disc brake pads.
    1. Install the inboard front disc brake pad.
    1. Install the outboard front disc brake pad.
Caution. The outer pads are left and right. put left on driver side.
  1. Position the front disc brake caliper on the front-wheel knuckle and install the brake caliper pin bolts.
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif WARNING: It is necessary to depress the brake pedal several times to position the front disc brake caliper piston before driving the vehicle.
Apr 23, 2009 | 2001 Nissan Quest
Hi, I have had the game thrillville off rails for ever and i have never used it because i dont know what do to. The box contains 3 dics and it says..disc 1..disc 2..and..disc 3. i have tried every disc and...
You need to install the game first. Install the discs in order starting with disc 1. Once you put it in the CD/DVD drive and close it, it should bring up the install screen. When it needs disc 2 and 3, it will prompt you to put them in. If disc 1 does not start installation, then you are most likely missing a disc that would be called "Install Disc". Hope this helps and if it doesn't, let me know.
Apr 10, 2009 | Logitech Dual Action for Pc (963292-0403:)...
Hunting Unlimited installed, won't play,does it come w/2discs?
in this it require the disc because the backup files did not stored correctly in your installed program. so insert the disc select all the docments and store in your system to install
Mar 20, 2009 | Video Game Consoles & Games
Lexmark X73 All-In-One InkJet Printer Logo
173 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
