Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I CANT SET UP MY PRINTER TO MY COMPUTER
I LOST THE WINDOWS INSTALLING SOFTWATE
    Brigadier General:
  • 4,090 Answers
Software download is available fromm the kodak site
SUPPORT TAG and search for model
Please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
Testimonial: "thank you it was very helpfull"
Tip
Installing canon mutipass F80 on windows xp
If you are having problem installing canon multipass F80 on windows xp, you are not alone. This is the process:
Power on the printer
Connect the US cable to the computer
Allow windows xp to find new hardware
choose the option that allows you to locate the driver
Point your computer to the location of the downloaded driver
choose windows2000xp
then allow windows to install the driver
After windows has finishing installing the driver, run set up again from the file you downloaded. You will be ok and ready to print.
on Mar 23, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Computer shows printer installed but will not send image to printer to be printed
try to uninstall and reinstall the printer softwate and drivers, using the control panel to remove("Add and Remove Programs" in Win XP), and reinstall using the Disk or downloaded file from Manufacturers website which you can get the most Updated software and Drivers from the Mfgr. Website (Usually software\Drivers, or Support\Downloads) enter model and OS (ex Win XP or Win Vista, or Windows 2008),
I Hope this helps, please give a good rating if it does, Gomez
Jul 02, 2009 | Office Equipment & Supplies
Were can I find install help for my X83 lexmark lost my CD
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
May 23, 2009 | Lexmark X83 All-In-One InkJet Printer
Cant instal the printer to mi computer
Setting up or installing a printer in Microsoft Windows. Issue:Setting up or installing a printer in Microsoft Windows.
Solution:There are two different methods a user can install a printer in Microsoft Windows. Below is additional information about each of these methods listed in the order we believe a user should try installing their printer in Microsoft Windows.
Before being able to install your printer you must have the software that was included with the printer. If you've lost the software for your printer you can download the drivers for your printer and use the drivers to install your printer. A listing of printer manufacturers and links to their associated drivers pages can be found on our printer drivers page.
Setup a printer using printer software
Every printer should come with the software used to install a printer in Windows. Although not all installations are the same the steps for installing this software should be similar to the below steps.
  1. Connect the printer to the computer and a power outlet and make sure it's on.
  2. Insert the CD that was included with the printer. If the CD does not automatically start the install program open My Computer, double-click on the CD drive, and then the Setup or Install file.
  3. Follow the installation wizard and your printer and its associated software should be installed successfully.
Installing a printer only using the drivers
In addition to the above steps a users can install a printer in Windows only using the printer drivers. This is recommended if you only want the printer to be installed but not the additional printer software programs that are often included with the installation and/or you've download drivers.
A listing of printer drivers and software downloads can be found through our printer drivers page.
Note: if you've installed the printer doing the above steps these steps should not be necessary unless you encountered errors.
  2. Click Start, Settings, and Control Panel.
  3. In the control panel double-click the Printers or Printers and Fax icon.
  4. In the Printers window click the Add a printer icon.
  5. After completing the above steps the Windows Printer Wizard will appear. Click Next, to start the wizard.
  6. Windows will prompt you if you're installing a Local or Network printer. If the printer is connected to your computer choose Local printer attached to this computer and click Next.
  7. When prompted for the location of the drivers for the printer. Browse the computer to the directory of your drivers or point it to the CD that was included with your printer.
Testing the printer
After the printer has been installed in Windows you can use Windows to print a self-test page to make sure the printer is working by following the below steps.
Microsoft Windows 98, 2000, ME, XP, 2003, and Vista users
  1. Click Start, Settings, and open Control Panel.
  2. Double-click the Printers or Printers and Fax icon.
  3. Right-click on the Printer you wish to test and click Properties. If you do not see your printer listed your printer is not installed. Seedocument CH000939 for additional information about installing a printer in Windows.
  4. In the Printers Properties window click the Print Test Page button.
  5. If the printer is able to print a test page, you're printer is installed and setup properly. However, if you're unable to print in other programs it's possible that the program you're attempting to print from has issues.
Mar 23, 2009 | Office Equipment & Supplies
Help with installing printer
Drivers, Software, lost C.D....come this way!
If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
Nov 18, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Acer TravelMate 5510 internet settings
I suspect your xp is missing some drivers, including your wireless card.
you can download drivers from www.acerpanam.com
Jul 21, 2008 | Acer Aspire 5050-3242 Notebook
Cant install printer without disk
You need to download the driver software ( same you got in the disk ) from Lexmark website.
Download software into the computer where you are going to install the printer. It is important that you do not connect the printer before installing software.
Install the software downloaded and connect printer only when explicitly required by software setup program.
Here is the driver download page , select your windows version and start download.
Regards
Jun 04, 2008 | Lexmark Z640 InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
44 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
