Question about Hitachi 43FDX20B 43" Rear Projection Television
Set comes on by itself sometimes for short intervals and occasionally for hours.
  • 111 Answers
This can happen for a few different reasons. The first being the most popular, is that something around the set or in the same general area is giving off a similar signal that the on command gives on the remote. This actually happens from time to time at my home. Also it could be because a button is stuck or sticking on the remote or the front of the set. good luck
Posted on May 07, 2010
  • rube_render Jun 15, 2011
    Keep the $12 bucks.
Francis Francis X1. Why does it work sometimes and sometimes heater trips GFCI?
take it to an appliance repair shop to have it checked out
the trip is working but if you ignore the problem you may get electrocuted
Dec 25, 2015 | Coffee Makers & Espresso Machines
My display has the wrench icon and the time icon and it says "OFF" on the display on the dash. What does this mean? and how do i get it off?
Programmable service interval
The purpose of the programmable service interval is to provide the consumer and dealer with a convenient reminder for routine maintenance. When your vehicle leaves the factory, this feature is set at 50 hours. You must enable the programmable service interval before it
can be used.
Once the service interval mode is set with the hours when service is due, the hours of actual engine operation are subtracted from the set
hours until 0 is reached. When the counter reaches 0, the wrench icon will flash quickly for 5 seconds each time the vehicle is started as a reminder that the periodic maintenance is due.
To set the hours, press and hold the mode/override button until the wrench icon flashes. When it begins to flash, release the button. The setting will increase by one hour each time the button is pressed.
Pressing and holding the button will allow the numbers to escalate much faster. When the desired time increment is displayed, release the button and wait for the wrench to stop flashing. When the wrench stops blinking, your service hours are set.
NOTE: If you scroll past the intended number, hold the button down until the count turns over to 0. You can then reset the number.
If the service interval is enabled on your ATV and you wish to turn it off, toggle to the service interval mode. Press and hold the mode button for approximately 7 seconds until the word OFF appears in the
Rider Information Center.
May 08, 2014 | Polaris 2007 Sportsman 700 EFI
We have the RCA HD52w59 projection tv. The tv shuts itself off at different intervals. It takes approximately 1 minute to be able to turn the power button back on, however, I have to do that many times...
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | RCA HD52W59 HDTV Projection Television
Lexsor 32" widescreen LCD TV
sounds like av panel needs replacing................
cheers
Mar 26, 2011 | Televison & Video
Why are there 6 hour 8 hour an 10 hour timers to defrost a self defrosting refrigerator
Good day,
The decision as what the time interval of a timer should be is determined by engineers and field tests.
There is more to the timer than interval. Timers are usually listed as 8 hours 21 minutes, 8 hours 30 minutes ect. The minutes is used to designate the time the control stays in defrost.
A general rule is if the interval is longer, the minutes in the defrost cycle is extended to compensate.
Other factors come into play such as the wattage of the defrost heaters and the defrost thermostat temperature.
The trend today, with timers is to extend the interval to make the machine more energy efficient.
There is never an issue to defrost more often then the original, but it will run the heaters more often, and cause increased operating cost and shortened heater life.
The short and long of it is you can use a 6 hour timer in any machine if the timer motor wiring is the same and the duration is long enough, but with the costs listed above.
Jul 22, 2010 | Jenn-Air Refrigerators
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
Vizio shuts itself off
I have found that turning off the power for awhile will work as a temp fix for a couple of days and then just repeat the process.
Jun 12, 2008 | Televison & Video
Black has turned blue and shutting off
That usually means the x-ray protect circuit was triggered. The set is going into protect shutdown for some reason. It may be a valid trigger to a lame problem or a fault in the detection circuit itself. I would hang a scope on there and just watch to see if there is a strange movement in voltage values, and if so, troubleshoot it from there. The blue picture is a result of a convergence problem. If you don't know much abou TV repair, I would suggest taking it to a Toshiba authorized servicer for proper diagnosis.
Jan 29, 2006 | Toshiba 32A43 32" TV
Hitachi 43FDX20B 43" Rear Projection Television Logo
115 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
