My fujitsu split system blows warm air after about
My fujitsu split system 5 air conditioner starts to blow warm air after working fine for about 1 hr. Its about 10 yr old. Well maintained and serviced regularly every 6 mths. Can't remember the model. Whats the problem : 1.Compressor? 2.Capacitor? 3. Gas leak? 4.any other causes?
  • 308 Answers
There is not really enough information here to properly answer your question. I can make a couple of observations for you though. 1. Compressor, yes this could be the problem, but it is not quite that simple. Is the compressor running when the hot air starts to blow? 2. Capacitor, no I don't believe this is the problem, as if it were a capacitor problem, chances are the unit wouldn't even start. 3. Gas leak, again no, if it were a gas leak, then you wouldn't get an hour of good run time when the unit starts up, repeatedly. Hope this helps.
Posted on May 07, 2010
Testimonial: "very helpful n my question answered based on the info given. "
Why doesn't it blow warm air?
When batteries in the thermostat get low the inside unit will come on but there is not enough power to start the compressor cycle.
Apr 10, 2016 | Heating & Cooling
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
My tadiran split system air conditioner is blowing warm air
if its warm air like really hot then you switched the unit to heat mode
if its blowing air in room tempereture then there is a gas leak somewhere ,so you'll have to find the leak source and after that fill the unit with freon gas.
Aug 26, 2014 | Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
Blowing warm air inside,blowing cool air outside
The odds are you are low on refrigerant charge and the compressor is going out in over load.
Aug 10, 2009 | Dometic Rooftop RV Air Conditioner
Evaporator vibrates and a noise and air gets hotter
When was the last time you cleaned the washable filter located behind the front flipup door of the unit? All mini-split systems are notorius for having dust build up on the blower vanes and as it runs it pulls humidity out of the air causing that dust to become like a past e
and changes the angle of attack on the blower cage. Check your filter and take some compressed air and blow it out real good and see if that helps.
Feb 01, 2009 | Fujitsu 24C1 Air Conditioner
Blowing out warm air
This could be a refrigerant leak. Before you call out a service technician, clean the filters and then try to see if it works. If it doesn't then get the unit serviced.
Hope this helps
I take the time to answer your questions, so please rate me.
Mat
Oct 16, 2008 | Electrolux E23CS75SS Air Conditioner
Fujitsu split level
Check for errors like blinking indoor light if present. Reset the error by disconnecting power supply from the unit for 10 sec. and "on" the unit. If the error persist, some parts of the unit may be defective and need to replace. Like room air thermistor, coil thermistor in the indoor side or the relay board. Some safety device in the outdoor may give in, some outdoor parts may be defective. You need a qualified technician for the this problem.
May 17, 2008 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
314 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
