Question about Karcher 2500 PSI Pressure Washer
My thatcher runs only when the choke is on, what
I Just bought a Thatcher with a Honda 5.5hp engine. It is practically brand new less than 10 hours, but has been sitting for the past four years in a garage. It starts right up but will only stay running with the choke on. Would appreciate any advice. Thanks Miguel
Gasoline these days has a very short shelf life (three to four weeks)
have your crb. cleaned by a quilified tech. and be sure to remove all fuel from your engine and gas tank if you intend to leave it for longer than a month. (it won't go bad if it isn't there)
Posted on May 17, 2010
    Brigadier General:
  • 4,090 Answers
And owned by a little old lady who only used it after church?
clean/change and re oil the air filter( very light machine oil and sparingly, just a few drops not a soaking), Change the oil in the sump if its a 4 stroke. check the settings on the air intake screws
make sure you are using fresh fuel,
clean and replace the plug . Finally check the float level in the carburretor it could be stuck or has a hole in it and is not set correctly. If you are unskilled in this it is better to have a lawn mower mechanic to assess it for you. Cheaper in the long run.
Please rate my help++++Thanks for using FIXYA
Posted on May 07, 2010
What party does Jim Hacker represent?
The programme tries to be as apolitical as possible, but he could well represent a Tory minister. Later on Margaret Thatcher appeared as the Leader of the Opposition, which would suggest that he is Labour. Maybe he is an early form of New Labour?
Sep 04, 2016 | Yes Minister (1980)
I have a Model# 917.370448. How may I remove the blade to install a thatcher blade?
block the blade with a block of wood, then undo the blade bolt (normal thread) bolt will probably be a 14mm ( 9/16")
Apr 10, 2016 | Garden
Kodak office 0hero 6.1 paper jam will not clear
I had this problem and the only way I found to fix it was to turn the printer off and left it unplugged over night. the next day it started right up and was fine. not sure if this helps, but that's what I did to fix it.
Jan 01, 2013 | Kodak Office Hero 6.1 Printer
I will be working on the internet and suddenly the connection is dropped. It will restart when I unplug and replug in. Will run fine for a few hours and then stop again and have to unplug/replug. All...
I would call the professional and have him replace/repair it for starters. There is obviously something wrong with the hardware or the connection of your Internet Provider, ether way the install should test the connection and stand behind his installation. If you paid this guy demand, politely but firmly of course, to repair it. 2DAYS OLD, I would be livid. By the way I do the exact same thing as your professional.
Nov 09, 2012 | NetGear N300 Wireless Router
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
Sir, i bought a brand new Passion PRO bike in May 2011. I am starting problem from the first day. (i.e.) the morning start is somewhat good but the bike is jerking as if their is some blockage in the...
this is not a complint. Only cold starting problem. Either you warm up the engine by closing the choke lever half and opening the throttle slightly or try with closing the piolet screw half turns, in this case you get less milage for your bike.
Jul 26, 2011 | 2011 Hero Honda Passion Pro
How to I change and attsch the thatcher and the aerator
On the link below it will tell you how to change the attachments.
http://www.littlewonder.com/08_tillers/410703%20Tiller%20Attachments.pdf
Good Luck and please accept the answer.
Sep 25, 2010 | Mantis Aerator Dethatcher Combo
New honda hrr auto choke hard to start
sounds like it may need the carb clening out, but it could be the auto choke not closing when cold. there was an issue with some of the early auto chokes on the gcv135/160 engines so check to see if the choke flap is in the closed position when starting from cold, run the engine for approx 10-15 minutes and see if the choke flap has opened fully.leave it to go cold and see if the choke flap has returned to the closed position
Apr 12, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
I have a Honda GCV 160 LAWNMOWER IT WILL ONLY RUN WHEN FULLY CHOKED
BEFORE you go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, runs for 10-30 seconds, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers ---- http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Mar 31, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Searching - user manual for Wadkin BAO/s planer thicknesser
www.machines4wood.com
I Also have a BAO 12 and im trying to find out about the starter as i need a new one. But the company above have a copy which i am ordering. His name is Ben Thatcher.
Hope this helps Rob
Dec 02, 2009 | Tools & Hardware - Others
Karcher 2500 PSI Pressure Washer Logo
199 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
