F61 error message
When i try to play my system, an F61 error message comes up. what does this mean & how can i fix it ?
dvd home theatre sound system
  • 158 Answers
NEED TO CHECK YOUR FANS AND THEN UR AUDIO STAGE.
Posted on Feb 10, 2009
  • RAVI CHETTY
    RAVI CHETTY Jul 20, 2009
    Unit is going into protection.Check outputs/audio stage.
SOURCE:
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
F61 appears on my setero when i push play
my dear friend. this error message means something is broke on the audio power.
the unit give that message when the chipset find fix current or signal on any audio channel.
the most common means you have to change the audio amplifier unit. sorry but i know is the true.
Jun 15, 2009 | Panasonic SC-HT830V System
Error Message F61
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
Aug 08, 2008 | Panasonic Home Theater System System
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
SA-HT680 F61 Error
Typically the F61 error is a protection error indicating that there is a problem with the output amplifier section. The failiing part is usually IC501 (part number RSN311W64D) which costs about $95. Have this unit checked as there are other possibilities.
Dan
May 05, 2008 | Panasonic Home Theater System System
T v and home theatre sony bravia
As most home theatre systems offer no analogue audio input and only use the audio coming from the dvd being played the short answer is no.
If your home theatre system has a digital input and the tv has the corresponding output then yes you could me able to connect the two. Otherwise you could try to get hold of a analogue to digital converter and convert the tv's audio out to digital.
Jan 11, 2008 | Audio Players & Recorders
F61 error message
u need to see a tv repair man he will order the party a amplifier chip that fixes the problem , however he wioll have to do it as you need a specilist tool to remove the old one as is has a twelve pin plug, it will costaround $ 100 INCLUSIVE OF LABOUR.
Dec 09, 2007 | Panasonic SC-AK600 CD Shelf System
114 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
