Question about Emerson EWF2703 27" TV
What numbers does the tv need to be at so that you are able to have a clear picture
  • 111 Answers
This all depends on what you decide looks better to you. there is no preset number or level to be able to set .This is a crt set so the picture should be good anyway
Posted on May 07, 2010
How do i reprogram a clear digital LCD 13in clear tunes prison tv
you dont,you throw it away and get a flat screen hdtv for cheaper
May 09, 2015 | Televison & Video
My Sharp Aquos has lost it's picture brilliance on all channels.
Try adjusting picture settings from tv menu, if this does not work your tv has a bad crt board in need of replacement
Jul 29, 2008 | Televison & Video
Goldstar TV no Picture
What is the exact model number to your tV?
Apr 28, 2012 | Televison & Video
I have no picture on my JVC AV-27730 tv. Where is the picture tube and can i replace it myself?
Hello
Picture tubes are available at electronic spare part shops. You have to give them the number and type of the picture tube, to which your JVC TV has. Picture tube, along with its Yoke fittings are integrated, and you can replace it by yoursef at home. Be very carfull in handling the picture tube, as they are highly vacumed, and will explde by hard hits. There will be four seating screws on the four corners of the picture tube, and these slots will clearly alaign if the picture tube selected is orginal number. Diamentions of these holes will be different to spherical and flat picture tubes. So you must first aware of the type of picture tube, which the TV has fitted earlier. OK.
Mar 06, 2011 | JVC AV-27730 27" TV
Dont have the model number as i am at work however it is an older model projection tv. I think it is 65in looks like the one above. However i came home turned the tv and the picture is distorted. the...
Picture distortion in your rear projection TV is because of failure of convergence out ICs that need to be replaced.
Qualified TV tech will fix it under $150 or $200 and if your are good in part soldering in circuit boards and have electronics knowledge then can replace by yourself.
Required ICs can be purchased from Part Store.
Oct 27, 2009 | Sony KP-57WS500 57" Rear Projection...
Cable Tv Interference
Sounds like the cable signal getting to that TV is just not strong enough.  This could be due to the number of connection and splitters leading to it.  Set it up with a coaxial cable that connects as close to the incoming cable as possible and not split it along the way.
Jun 02, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
The picture is not clear
Good Day por24;
The most common concern with rear projection TV's that have pictures that are not clear is that the lenses and mirror needs to be cleaned. Most manufactures allow access to this area, lenses&mirror, from the front of the TV by removing the screen ***'y. That is the easiest way but not always the most obvious.
If the the brand is Phillips/Magnavox the problem will more than likely be contamination of the CRT's fluid,Ethylene Glycol, in which will have to replaced.
If not clear meaning the colors are seperated then the TV will be experienceing a convergence problem.
Good Luck, hope this was helpful, if not rtn with brand an model number, Big Irish.
Jun 21, 2008 | Televison & Video
I have a 53 inch Sony Projection TV that is about 4 years old. The only service ever done to it was an inside dust cleaning by a technician maybe 3 years ago. The color started being more green over time...
Please count the blinks if it is a repeating pattern and post the model number. This is a relatively common problem, but the solution is dependent upon the model number.
Thanks,
Dan
Apr 17, 2008 | Televison & Video
Picture failure
Do not have a clue without a model number and make. Are we to be fortune tellers here too?
Oct 04, 2007 | Televison & Video
Emerson EWF2703 27" TV Logo
57 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
