Question about Craftsman 675 Torque 190cc 21" RearBag Push Lawn Mower ()
Blade doesn't turn and when i try to pull the cord it wont even move
  • 143 Answers
Is it possible that you had the mower on it`s side to long and the cylinder filled with oil?. If so remove the spark plug and turn the engine a number of times or blow it out with compressed air. Stephen.
Posted on May 07, 2010
Why won't Toro start - we have electric start and pull cord won't move?
pull on the bail handle tape it down try to turn blade by hand with plug removed if you can move poure a little oil end cylider and spin it sevseal times put plug back in start it i think it heat siezed check oil level to thats what us red necks do let me know
Aug 27, 2014 | Garden
Brand new craftsman 190cc lawnmower pull cord will not pull out
New mowers some times comes with a safety block on the blade and this has to be removed before you can turn the blades
Jun 30, 2014 | Craftsman Garden
Lawnmower blade wont turn
Probably bent the shaft. Disconnect the spark plug to prevent accidental starting and lay the lawn mower on its side. Slowly turn the blade with your hand and watch the center of the shaft. If it wobbles at all it is bent. $150 to $200 job. Probably time for a new mower.
Mar 09, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
My HUSQVARNA HU775H will not start. I just replaced the spark plug and still nothing.
are you saying it wont even allow you to pull starter out ? if this is so , then remove the spark plug completely and try if it still wont pull then seems it was overheated and now piston is fused to cylinder wall , if it does allow u to pull it , ck your reed valves in head seems there not releasing when they should also have a look at rope in starter it could be all twisted up keeping you from pulling it out as well
Mar 08, 2013 | Husqvarna Garden
MODEL SERIES A4 HIT SEWER CLEAN OUT NOW PULL STRING WONT PULL OUT , i AM GUESSING SHEER BOLT?
Let's see if we can get thru this problem leaving you with a smile on your face rather than a frown.
First look under the deck of your mower. Check to see if the blade may have bent and wedged up against the deck bottom to the point that would not allow the pull cord to be pulled, if this is so remove the blade. Second check with blade off to see if the engine will rotate, i.e pull the pull cord . If the engine rotates with no obstructions you should install a new blade. Third if the engine still doesn't start then you have sheared the timing key. Remove the top cover to the engine and any other attachments, remove the flywheel, replace the shear key. You should then be good to go.
Take your time, take a look, it may not be as difficult as you think. GOOD LUCK>
Jul 04, 2011 | Mtd 22" Yard Machine Push Mower
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy-Bilt Briggs and Stratton 675 series lawn mower. The pull cord is stuck and will not move. I can lightly pull the cord repeatedly and the cord slowly allows me to pull more but if I release it...
Take the plug out and try to move the blade. If the motor won't rotate, the problem might be with the motor and the cord can't move because of it.
Gary
May 19, 2011 | Garden
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
Just got a lawn mower and i dont have the manuel. i mowed about 50ft of lawn before it died. its a turn key but even when i pull the cord it feels like its jammed and wont start. It has fresh oil and gas,...
Use a thick gloves and try spinning the cutting blade. There could be a problem with  the shut off brake. Try pulling the lever. Check if the cable is busted.
Nov 02, 2009 | Garden
Craftsman 675 Torque 190cc 21" RearBag Push Lawn Mower () Logo
162 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
