Question about Kitchen Appliances - Others
How to use optima gr1700 barbecue grill i dont have the manual for this gadget
5 Suggested Answers
  • 833 Answers
SOURCE: Kenmore grill 141.52270
I don't know about downloading...All Kenmore products are made by other manufacturers. I don't know who makes the grills but you may want to explore Sear's own site to see if a comparable unit is shown...or simply buy one from Sears for a few dollars. Go to their parts site.
Posted on Mar 16, 2008
  • 770 Answers
SOURCE: no gas flow from barbecue
Yes, if you have gas flow from your cylinder, then nothing when you turn on the valve on the grill..(You should hear...and smell the gas), then the problem is either in the regulator assembly or in the valve. Both items are cheap and easy to replace and parts are abundent at most hardware stores.
Posted on Jun 19, 2009
venexcsd
  • 1185 Answers
If you used a power washer you may have driven rubbish into inlets for the burners, or as my collegue has already pointed out, water.
If the BB is empty then turn it upside down onto some newspaper and see if you get a water discharge..
The gas is normally supplied through a hole into the burners and is mixed with air on the way in so that it combusts out of the holes on the burner
If none of them are lighting I would do the upside down bit first , if that does not fix it then start looking at the gas inlets
  • 34 Answers
SOURCE: Mice in our barbecue grill. What to do?
Is this a problem all the time or just in storage? If it is in storage make sure they have not place to climg on to get in. Also in storage you can put steel wool in the bottom openings and this should keep them out.
You can also put mouse poison around the base while in storage.
If it is a problem during normal use make sure they don't have anything close by that they are using to climb aboard.
Posted on Apr 17, 2010
I've lost my instruction manual. Where can I get another one?
Easy! From this pdf page:
http://docs.barbecues.com/PE-Links/Brinkmann/Brinkmann-815-3060-4-manual.pdf
It is the real instruction manual!
Jul 02, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
Tip
How To Change Remove Replace Propane Tank on Barbecue Grill
<utube src="o16WpkquQxA"></utube>This video will show you how to replace the propane tank on your barbecue grill.
on Aug 04, 2013 | Grilling
Tip
How To Keep Barbecue Grill Grate Clean and Rust Free
<utube src="qFo0unxnSHQ"></utube>This video will show you how to clean and keep your barbecue grill grate clean and rust free.
I dont have one
Grilling can be great! It makes for incredible meat and veggies if you do grill. Tender meats, delicious rubs. I'd suggest starting when you have the time. Less fat than frying.
http://www.saveur.com/article/Techniques/Barbecue-101
Jun 04, 2011 | Grilling
Need manual for weber silver grill
On the Weber website, go under "Help" and then there's a section called "Download a Manual". You'll have to know (almost exactly) what model grill you're looking for, because otherwise searching through each manual would take you a decade.
May 18, 2010 | Weber Genesis Silver B Grill
Flames shoot out the front of charbroil grill melting the knob
maybe put the barbecue in different place more out of the wind
Apr 27, 2010 | Char-Broil CharBroil Master Flame Gas...
New grille for a Meco Swinger II Smoker Grill charcoal barbecue
Try http://www.shop.allinone.co.uk/eCommerce/product.aspx?cat=193&prod=6229
Jonathan
Jun 14, 2009 | Meco 4400 Swinger II
Grill
http://www.fiestagasgrills.com/customer.support/content/manuals.html
Apr 20, 2009 | Fiesta Optima EZD45055 Grill
Bunners do not get hot
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Hope this helps!
Apr 20, 2008 | Coleman LG40811E Grill
Kitchen Appliances - Others Logo
392 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
