Question about Panasonic Linear ES 8003 W Electric Shaver
It stops running after 15 seconds or so. Can it be fixed?
  • Panasonic Master
  • 1,600 Answers
If the charging light illuminates when you charge the shaver, almost certainly the batteries need to be replaced. You will find suitable replaceent batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
If this is not something you can do yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Posted on May 08, 2010
HOW TO ADJUST THE CARB. ON A MODEL P3314 WILL START AND RUN FOR ABOUT 15 SECONDS AND THEN STOP RUNNING.
suspect that the diaphragm is going hard and is not sucking the fuel up from the tank properly
rekit the carby
Oct 02, 2016 | Poulan Garden
36 cc craftsman 16 inch saw replaced fuel lines fires up but wont stay running it excellerates for about 15 seconds
Check to see if exhaust is stopped up Clean or replace it then it should run good,If not replace fuel cap.Take fuel cap off and start.if runs and accelerates then replace fuel cap. If not the exhaust is stopped up with carbon clean it or replace.
Nov 01, 2014 | Garden
Just start 15 minutes and then stop
Pull the cover if necessary to see if the fan is spinning. If it's running 15 seconds, your door switches are probably ok, and the touchpad is working, main fuse ok. All that leaves is the circuit board and the magnetron.
Personally, I prefer microwaves with twist timers, not touch pads. A lot less to go wrong.
Nov 22, 2013 | Panasonic NN-S969 Microwave Oven
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
The microwave oven will only run for 15 seconds
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
May 15, 2010 | Panasonic Microwave Ovens
Just replaced lamp and sony wega rear projection turns off than 15 seconds later turns on what do i do to fix
CK your Lamp Fan, if it is defective and stops running Lamp will shut off in order to keep from burning it up.
If Fan starts and stops it is defective. Fan is to run at all time.
Mar 17, 2010 | Televison & Video
Brand new Dryer starts then stops after 15 seconds
Stop what you are doing. It is under warranty. This will be more costs and it is not necessary. It is a mfr problem.
Feb 08, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Keeps stopping after 10 seconds of operation
Motor is bad and needs to be replaced. It is drawing too many amps and tripping its overload. Once cool it will run again only to stop. About $100 for the motor.
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Panasonic Linear ES 8003 W Electric Shaver Logo
157 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
