Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
I've connected my macbook pro with a DVI-D to HDMI adapter cable. The autosource briefly detects my computer, then gives a "no signal" indicator. Meanwhile, my computer detects the display, but I have no control.
  • 111 Answers
It sounds like there is a conflict in the display types. the tv and the mac must be set to the same type of signal and display type. for example, your mac is set to output at 1080x640, but the tv is set to 720x480. They have to match or they will conflict each other
Posted on May 07, 2010
Why is there no Signal on the DVI input with my MacBook Pro?
Is your television DVI-D or DVI-I?
If it cannot see the digital display, that might be the problem.
Jan 20, 2013 | Computers & Internet
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
Aug 29, 2017 | Computers & Internet
I am trying to connect my macbook pro computer to my Panasonic Viera using a VGA > HDMI converter, connected through to the HDMI port on the TV. The TV screen remains black on the HDMI setting. I...
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Oct 13, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How can I hook up MacBook Pro with Optoma 1690 Projector? Am I supposed to hit a certain function key to get Projector to see MacBook
You may need a certain connection (MiniDisplay Port to DVI, or MiniDisplay Port to VGA). If you're connecting to an HDMI-compatible projector, you'll need an adapter. You'll also need an adapter if connecting your MDP (MiniDisplay Port) to a DVI or VGA port. Here are some helpful links:
#1 MDP Adapter Video (YouTube)
#2 MDP to HDMI Adapter (RadioShack)
#3 MDP to VGA Adapter (Apple Store)
#4 MDP to DVI Adapter (Apple Store)
http://www.radioshack.com/product/index.jsp?productId=3898890&CAWELAID=447271885
http://store.apple.com/us/product/MB572Z/A
http://store.apple.com/us/product/MB570Z/A
Mar 12, 2010 | Apple MacBook Pro Notebook
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
Dec 29, 2009 | Apple Computers & Internet
How do I connect my macbook pro to a Pioneer Elite HDTV?
Newegg.com carries a mini-dvi to hdmi cable that
Item#:N82E16812200375 it's listed as "StarTech MDVIHDMIMF Mini DVI to HDMI Video Cable Adapter for Macbooks and iMacs"This should hook directly into one of your HDMI connectors on your HDTV.
Hope that helps
Oct 31, 2009 | Apple MacBook Pro Laptop Computer with...
I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally. -Ken
Jul 13, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
Apple Macbook pro video out to VGA port ("d-sub") on Optoma
There's no solution. it will not connect with macbook pro or any other mac. as on the phone with all technicians and they do not know what to do. I had the unit replaced and still would not connect.
Mar 19, 2008 | Optoma MovieTime DV10 Multimedia Projector
Televison & Video Logo
217 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
