Question about KitchenAid Dishwashers
Kitchenaid Dishwasher KUDS24EPL4 bottom door seal how to install.
  • Johnh339 May 07, 2010
    Hi Phil,
    The dishwasher started to have a leak on the right side from what appeared to be with the door seal or from the tub spacer.
    I replaced the door seal ( the long piece that in on the inside tub not on the door itself).
    The leak continued on the right side and from observation was coming from the tub spacer ( the plastic piece that sites by the door hinge and returns water from the door.
    When you order those parts it comes with a bottom door seal so since the other seal was replaced then I went ahead and planned on replacing the bottom door seal.
    That seal however as I looked at it could be installed on one of two lips on the door and it could be installed to in either of two directions.
    After I replaced the various seals the leak ( as with all good intentions, the punishment soon follows !) became a solid flood from across the "whole' of the bottom of the door.
    At this point I had one of three options.
    Buy a new dishwasher and replace it in the dead of night so as to avoid my wife's " I told you to call someone as you can't fix things you are a Computer Geek".
    However, having been married for 40 years now, I have found that a dozen roses, box of chocolates and a gift card to Nordstrom will for the most part make up for my lack of " Which end of the screw driver am I supposed to use " Geek abilities I was looking for a possible alternative to all of that.
    Or I could use Duck Tape to seal the entire bottom of the dishwasher ( using black tape to throw my wife off for a while), tape the entire underside and lay a small plastic pipe to carry away the water so as ensure no one would notice the leak.
    or
    Ask for help.
    While Option one , replace the dishwasher is still on the table I am going to try the fix you sent and maybe still salvage some shred of dignity
    I was going to add a fourth fix of " shaving my head and becoming a groupie for Lady GaGa but I really don't like her music that much and since I am already " almost bald as a cue ball" not many would notice the radical change in my hair management.
    I will let you know if the fix works.
    Thanks again
    John
    Well looks like Option # 1 ( Replace) as with the front covers off to watch where / if a leak occurs I noted the pump motor has a lot of corrosion on it and has leaks in 4 places, including one that leaks on to the pump motor wiring.
    I have always been a bit reluctant to mix water with a lethal level of AC power so a new machine is in the end a safer bet.
    The roses, Chocolate and Nordstrom would happen anyway !
    Thanks for your help, I did replace the seal. The " grove" that clips onto the lip of the door makes sense once you see how it seals the door when the door is closed.
    It did indeed fix my door leak but in doing so showed the motor and the floor under the motor which indicated the long term leak and corrosion.
    Not matter how I looked at that seal I could figure out how it actually sealed the bottom of the door.
    I kept looking at it while the door was open and couldn't see the logic of the design as it didn't make a seal.
    I think I needed a NCIS Agent Gibbs whack on the back of the head for that one !
    Thanks again.
    John
    President:
  • 949 Answers
The seal has 3 pieces, the long one snaps into the grove in the bottom of the inner door panel. The 1st image below will show the orientation of that seal (part 7).
The other 2 pieces are on the corners and the door has to be removed. Please see the 2nd image for details.
Before you do this, I have to ask why you are replacing this, if the dishwasher leaks when the pump shuts off (like a surge of water) then the issue is not this seal, it is related to the upper spray arm, it is ether come detached or it is broken or the tube that feeds the spray arm is broken.
Let me know if you have questions.
Posted on May 07, 2010
  • Philip May 07, 2010
    Hi John,
    Love the comments. I can relate as this is my 30th year of marriage.
    Let me know what I can do to help a fellow tech from being in the doghouse.
    Phil
KUDS35FXss is dripping from the bottom of the door
Bad door seal drain plug not knocked out of garbage disposal other would be main seal at pump u can take bottom dishwasher off and watch were coming from if it's at door then door seal if still has water when done then check drain and disposal drain plug hope this helps
Feb 21, 2013 | KitchenAid 24 In. Stainless Steel...
Kitchenaid dishwasher door leaks out bottom middle of door when it goes into drain mode?
You probably need to check the door gasket for proper sealing and maybe replace it if the dishwasher has been in use for awhile
Oct 13, 2012 | KitchenAid KUDI24SE Built-in Dishwasher
Water dripping from bottom of door
Hi.
Either the dishwasher is overfilling or the door seal is damaged. If the dishwasher is overfilling the float switch must be replaced. Check the door insulation first.
Dec 12, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I found some black plastic under the dishwasher and then found some more... it appears to be long as if it was the seal or something across the bottom of the door. Can you tell me what it is and what I...
Its hard to tell from the description what it is. Does it like item #4 in first link OR item #31 in second link. If it is item #31 in second link its soundproofing insulation that attaches to kick plate and has come loose,a couple dabs of super glue would reattach it to kickplate
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS30IVWH3/0593/0130000/W1005148/00003?blt=06&prst=&shdMod= item #4
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS30IVWH3/0593/0130000/W1005148/00005?blt=06&prst=&shdMod= item #31
If it is item 4 thatsa seal on bottom of door and needs to be there to prevent leaks
Gene
Aug 13, 2011 | KitchenAid KUDS30IVWH Builtin Dishwasher
Our KitchenAid dishwasher has been working great until just recently. It has started to leak small amounts of soapy water about half way through the process. I ran an empty load and it didn't leak. Ran...
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Answer 2 (Door seal replacement)
Hi
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repair person. The door seals on this Kitchenaid dishwasher are pressure fit into a metal channel that runs along the inside of the wash tub.
To install, simply remove the old seal paying close attention to which way it was installed, apply a bead of adhesive inside the channel, then install the new seal in the correct direction. A test fit prior to applying the adhesive is a good idea and if you are having trouble with one side being to long, try folding the seal in half, take hold of the looped end, and insert it under the door latch. The reset should go in properly. The new seal will be a tight fit which is the way we want it so it may take some force to get it fully seated. If the door is hard to close, then the door seal needs some more work.
Thanks
Rylee
Nov 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
I have a kitchen aide dishwasher ~ only about 6 yrs old ~ and it's the higher end model with the Wood panels , anyway , Its leaking water on the bottom ~ Is that the main seal ? and How hard is it to...
Hi
Thanks
Rylee
Sep 15, 2009 | KitchenAid Dishwashers
Door still leaks after replacing bottom seal
the bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.0d084cc.jpg
Dec 20, 2008 | KitchenAid KUDC25CH Dishwasher
I have a Kitchenaid KUDS25SHBL1 dishwasher that is leaking from the bottom of the door. I replaced the main gasket around the body that the door seals against, and it is still leaking.
Have you removed the outer door to check if the leak is coming from inside the door . also check the bottom door seal ? also check the around the soap dispenser as I have had to silicone around them to keep them from leaking before..let me know if this helps at all.
May 11, 2008 | Dishwashers
Leaking Dishwasher Help!
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Dec 12, 2006 | KitchenAid 24 in. KUDI02FRSS Stainless...
Dishwashers Logo
147 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
