Question about Acer 22" X223w LCD Monitor
Monitor won't come on
When i turn my monitor on it tries to come on then screen turns blue then turns black
  • 11,361 Answers
Most LCD monitors have common problem due to caps failure in the power supply, that will be the first place to check. Need to verify that you do have 5vdc and 12~18vdc from the power supply output.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 07, 2010
Gateway monitor 2100 won't turn screen on, blue lite is on as if monitor is. but screen is not on. can it be fuse or what ? is not v-card
It sounds like the lamp for your monitor is no longer receiving power. While you can attempt to fix this issue yourself I wouldn't recommend doing so as it doesn't mean it will work after you attempt it.
If the monitor is under warranty still then you should contact the manufacturer about a RMA. If the monitor isn't under warranty then you should purchase a new monitor.
Nov 26, 2011 | Gateway Computers & Internet
Well I have a Gateway Laptop Model MS2274 and it won't turn on. The light of On/Off is blue so it's on, but the screen remains pitch black. I connected it to recharge it and the light turns on too....
Try connecting an external monitor and see if your see anything. If you can then most likely your LCD monitor on the laptop is dead. Also try FN+ the monitor toggle key to see if you can get video.
Jun 20, 2011 | Computers & Internet
I have a dell monitor model e172fpt i have power when it turn on has white on the screen and turn on blue and black screen
not a expert just trying to help,,, try a different monitor and see if it works or not,, if you have same problem it is in the computer,, hope this help you
Feb 25, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Screen dialoge analoge and turns black i have no credit card then i dont know how to pay for asistance
I'm assuming turns black and blue then turns off? First make sure your connectors to your monitor and back of pc are secure. But it sounds like your video card needs to be reseated.
May 24, 2009 | ViewSonic VA721 17" LCD Monitor
The monitor goes on but no picture. when i turn
RAM problem. Fix the RAM properly in the RAM slot.
May 07, 2009 | Olevia LT26HVX 26 in. LCD Television
Digital Power Saving Mode
Go to your monitor power settings and turn off Hibernation and other monitor power schemes.
If this problem persist, request for more technical assistance from the manufacturers website
Nov 30, 2008 | LG W2252TQ Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Acer 22" X223w LCD Monitor Logo
194 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
